Bartop 2 player zero delay encoders not working
Hello
I have seen this posted and have tried to follow the guide but I am still having issues I have a two player bartop arcade
http://imgur.com/a/OoZnF
http://imgur.com/a/v4OVcI have two generic zero delay encoder boards one for player one and one for player two. I configure them just by pressing start and holding down the buttons and save them. In the menu everything is great but once I open a rom depending on which joystick I use to launch the game the other gets wonky. The directions are inverted up is down down is up etc and the buttons I mapped out aren't corresponding in the game my select button should be the lower button underneath the control panel but it is the hard punch button in a typical street fighter lay out . The game was tested in fba not mame
I have followed the advice posted here
https://www.reddit.com/r/RetroPie/comments/4p3uzo/2_zero_delay_usb_encoders_not_working_together/
And here
https://retropie.org.uk/forum/topic/5135/retropie-bosega-usb-encoder-issue/2
So I used putty to ssh into my pie and edit the cmd line and this is what I have
.***. Tuesday, 24 January 2017, 5:15:44 am UTC
***** Linux 4.4.38-v7+ armv7l GNU/Linux
***' |*| Filesystem Size Used Avail Use% Mounted on |*| /dev/root 118G 99G 16G 87% / ..|*|.. Uptime.............: 0 days, 00h13m02s .*** * . Memory.............: 477492kB (Free) / 752852kB (Total) ***@@* Running Processes..: 128 *****@@**' IP Address.........: 192.168.0.15 *******' Temperature........: CPU: 60°C/140°F GPU: 61°C/141°F
"""' The RetroPie Project, https://retropie.org.ukpi@retropie:~ $ lsusb Bus 001 Device 006: ID 0079:0006 DragonRise Inc. Generic USB Joystick Bus 001 Device 005: ID 0079:0006 DragonRise Inc. Generic USB Joystick Bus 001 Device 004: ID 413c:a503 Dell Computer Corp. Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty2 root=/dev/mmcblk0p2 ro$0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet loglevel=$level=3 logo.nologo consoleblank=0 plymouth.enable=0 usbhid.quirks=0x0079:0x00$9:0x0006:0x40
The dollar signs are not actually there i double checked it I think it was because my putty window was too small.
If anyone can help me I'd greatly appreciate I have been pullin my hair out with this project and I am so close to being done.
I have no experience with using the cmd line or anything along those lines last night was the first night I found out what ssh and putty were
Try clear all the joystick/gamepad by:
Quit ES by pressing F4, ran sudo ~/RetroPie-Setup/retropie_setup.sh
went to Manage Packages -> Core Packages ->
emulationstation -> Configuration and chose the option Clear/Reset Emulation Station input configuration.Restarted ES and reconfig controller in ES.
I got to the cmd line prompt but I have no idea how to do what your asking me to do everything I typed out didn't appear on the command line sorry for my ignorance but I don't know how to access this
Is there any way you can tell me step by step to access the sub menus I have no expierence with command line or anything dealing with retropie that isn't GUI
@egoo33 type the following in cmd line:
@jretropie
Yeah I typed that and nothing happens don't know how to clear them out -
@egoo33 make sure you type it correctly as some characters are capital.
