    FBA-Next Help.
    5 Posts 3 Posters 1.5k Views
      bagheera369
      I have tried and tried, every button combination I can think of, but I cant access test menu for CPS2 games (only games im running fba).
      I have tried holding start, tried start+every key, and then select+every key, but have had no luck. Wiki says hold start, but that does nothing here.
      Can anyone help me???
      CharcoC 1 Reply Last reply Reply Quote 0
        dankcushions Global Moderator
        what version of retropie are you running? the 'hold start' thing was only added in 3.7 and up, I think. if you're running an older version you could try updating lr-fba-next via retropie setup menu > install individual emulators.
        • CharcoC
          Charco @bagheera369
          @bagheera369 I can enter the diagnostics by going to the Retroarch menu in game by holding Select + B, choose Quick Menu -> Core Options -> Diagnostics and change it to Enabled and exit the menu. It's a toggle, if it doesn't work first time try again.
          I just tested here on 1944 The Loop Master and got to the diagnostics menu.
          Hope this helps.
            bagheera369
            Finally!!!! On my version there is not a diagnostics toggle where you pointed, but I dug through the options for the controls, and found the diagnostics menu set to "start+r3"
            So i changed it to an appropriate button, and we are now fully golden. I didnt know that the config menu there was actually gonna be useful. Thanks everyone!!!!
            CharcoC 1 Reply Last reply Reply Quote 1
            • CharcoC
              Charco @bagheera369
              @bagheera369 Glad you got it working :)
