Finally got everything up and running, still 2 minor issues
Hey guys,
I got my PI3 up and running retropie (latest version)
i hooked it to my infocus beamer with hdmi and everything works great.
I set all emulators at 720p resolution but i can't find the option to set ES/retropie to this res. so everytime i start or exit a game the resoltion will change from 720p to 572 something....... Any way to set it all to 720??And second issue is a known issue but i didn't find a fix for it...
I installed Kodi port and it works, but on exit Kodi i get a black screen and the only way getting back to ES is to reboot the PI.grtz,
Ruben
@G-Member Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first
(give details - and don't say "latest version" when requesting support)
If you want to run at 720p - just set 720p in
/boot/config.txt
rather than via runcommand.to fix kodi see this post
https://retropie.org.uk/forum/post/44231
This:
add
sleep 1; fbset -depth 8; fbset -depth 32
to the end of/usr/bin/kodi
before the exit or you could try Kodi 17 rc1 which I believe has the wrapper script sorted nowhttps://retropie.org.uk/forum/topic/6308/testing-kodi-17-release-candidate-1-available-for-retropie
Sorry, didn't noticed the read-this-first post.....
Thnx for your reply, just one question.....since Kodi was installed thru ES packages how can i update it to this rc1 version?grtz
@G-Member Follow the instructions in the link above.
Also post support questions to the support category. Moved.
