    Games stuttering a little bit
    retropie stuttestuttering
    66 Posts 11 Posters 29.2k Views
      knorde
      Hi there!
      I'm a new user of retropie (newest version).
      I love the system and i use it on a raspberry pi 3 B
      All works fine but i see many games (fast games) are stuttering a little bit when you run fast (nes: mario, megadrive: sonic etc).
      First i replaced my raspberry pi 3 B for another one but it have the same "problem".
      It is playable and very fun but the little stuttering is not fun :)
      Why is this happening and is there any way to fix this?
      Do other members recognize this little problem?
      Sorry for my bad english, i come from holland :)
      Greets Kees.
      • rbakerR
        rbaker @knorde
        @knorde https://retropie.org.uk/forum/topic/3/read-this-first
          knorde
          Sorry, my english is not so good, it will try:
          Pi Model or other hardware: PI 3 B
          Power Supply used: 5.1 V 2,5 A
          RetroPie Version Used: 4.01
          USB Devices connected: None
          Controller used: PS3 wireless
          Error messages received: No
          • rbakerR
            rbaker @knorde
            @knorde I do not recognise the problem. I need to know what emulator you are seeing this behaviour on?
              knorde @rbaker
              @rbaker
              ES Emulator Station (that is in the package from retropie).
              With the white background.
              It is not 100% stuttering, it is a little bit.
              Greets Kees.
                knorde
                I have created a movie zo you can see what happening.
                On the movie it is hard to see, but if you look good you can see it i hope :)
                www.kene.nl/stutter.mp4
                • rbakerR
                  rbaker @knorde
                  @knorde said in Games stuttering a little bit:
                  ES Emulator Station
                  This is not an emulator, it is a front end that allows you to select emulators. What emulator and what rom is this video?
                    knorde @rbaker
                    @rbaker
                    Do you mean the console?
                    This is de NES emulator (with the rom Circus Charlie).
                    • rbakerR
                      rbaker @knorde
                      NES emulator
                      Which one? Having watched the video, I cannot see anything. Try the other emulator options.
                        dankcushions Global Moderator @knorde
                        @knorde the video is in wide screen which isn't the default. have you changed some settings?
                          knorde
                          On the movie it is not good te see.
                          The emulator that i use is lr-fceumm.
                          I have tryed the other one but it does the same.
                          I have set the settings to widescreen so i have the game fullscreen.
                          But if i set it to 4:3 it is stuttering to.
                          It is not really stuttering, i don't know the right text.
                          If i type the dutch wordt "hakkelen" google says "stammer"
                          It is difficult to film.
                          The screen jumps always a little (maybe that is the right text).
                            backstander @knorde
                            @knorde
                            Make sure you enable "Game Mode" on your TV and you might have a look at the documentation about Speed Issues:
                            https://github.com/retropie/retropie-setup/wiki/Speed-Issues
                            • Z
                              zulueffendi
                              I bought a canakit pi b+ kit a few years ago and installed an old version of retropie .. in my limited memory brain i feel like it was version 2. Something. Well it ran awesome. Nes emulation was what i was after.. i wired my own arcade controls to the gpio..
                              Fast forward two years of really no use and the whole pi awaiting an arcade cabinet build.. i thought id see what was new in the retropie world so i downloaded the new version which is super streamlined now.. but now the shock sets in... I cannot run any nes roms at anywhere near normal speed...
                              Has anyone else had this issue with newer versions of retropie? Ive tried another sdcard. And lowering framerate to 640/480..
                              DarksaviorD edmaul69E 2 Replies Last reply Reply Quote 0
                              • DarksaviorD
                                Darksavior @zulueffendi
                                @zulueffendi Fine here. I'm using a pi2. Maybe your older pi is too slow. Oc it if you can and go to retropie setup and choose Update All Installed Packages so it also updates the emulators.
                                  edmaul69 @zulueffendi
                                  @zulueffendi try getting or switching to lr-nestopia if you are using lr-fceumm. Or vise versa. One of them is to slow on a b+. Plus you probably need to use lr-pisnes for snes and lr-picodrive for genesis
                                  • Z
                                    zulueffendi @edmaul69
                                    @edmaul69 i switched to nestopia and overclocked. It is much better but still slow. Its strange the nes emulation worked 100℅ a couple years ago,.. so imagine my disappointment
                                      Dochartaigh @zulueffendi
                                      @zulueffendi said in Games stuttering a little bit:
                                      I'm experiencing this myself 100%. Everything from like RetroPie 3.8 to 4.1.5 has Nintendo being 100% proper (60 FPS nearly constantly, no stuttering). Whenever I upgrade any Pi to the newest 4.1.11 version of RetroPie the lowly NES emulation stutters and stammers. WAY more evident on my Pi Zero 1.3's, but have noticed it just a tiny bit on my Pi 3 as well. Switching to lr-fastnes cured it but that isn't supposed to be as accurate or as stable as the default lr-fceumm.
                                      As I always say: this has been tested on multiple Pi's, multiple installs, multiple power supplies, multiple SD cards, etc.
                                      K Z 3 Replies Last reply Reply Quote 0
                                        knorde @backstander
                                        @backstander
                                        I have a panasonic tx-42as600e.
                                        Can't fine a option to set it to game mode.
                                          knorde @Dochartaigh
                                          @Dochartaigh
                                          It is also with the megadrive emulator.
                                          Is that working perfect with a older retropie version?
                                            Dochartaigh @knorde
                                            @Dochartaigh
                                            Megadrive/Sega Genesis never gave me any issues, even on the Pi Zero 1.3 it's been excellent.
