    Bluetooth Audio?
    bluetoothaudioraspberry pi 3
    1 Posts 1 Posters 912 Views
      maz
      I saw older posts around bluetooth audio, but those are out of date due to Bluez 5.0 (Raspbian Jesse) no longer supports ALSA. I kinda sorta got it working, but it required installing pulse audio and seemed to lock up system when I started games unless I killed pulse audio. It did work as I did get audio, but manual intervention was needed everytime the run command was launched. The quality (headphones) was fine, no delay like I read in other posts.
      I am no linux expert, so I couldn't figure out how to install this , but I stumbled upon https://github.com/Arkq/bluez-alsa which claims to re-add the direct integration of Bluez and ALSA. Could this work? Anyone think it is worth testing out? Or could tell me what I should copy and before I run his make file? I am only good at apt-get
