    Maximum number of wired controller
    controllerpi3
    12 Posts 5 Posters 3.1k Views
      messo
      What is the maximum number of wired controller that is possible to connect to retropie (on pi3)?
      I have 2 wired controller (PS2 with adapter) and I'm thinking to buy another one.
      Are there any problems with 3 or 4 wired controller? Does pi3 provide enough power through usb for all the controllers?
      messo
      • lostlessL
        lostless
        You should have no problem with using 4 controllers. They don't use much power. The maximum amount is determined by your power supply to supply enough power to the USB ports.
        • AndersHPA
          AndersHP
          Hope it's ok for me to revive this topic, but what about adding wired USB controllers on top of an already working iPac2 setup?
          Is this possible?
          I recently finished my bartop arcade, and it's really great with the arcade buttons and joysticks, but I thought it would be cool to add 2 gamepads also (preferably wired).
          Is it possible to have iPac2 inputs hardcoded into the CFG files and also have gamepad buttons assigned?
          This way, both players have 2 controllers each, will it not interfere in some way?
          My Gameboy
          • CapemanC
            Capeman
            Pi should be able to handle it, the only thing is you need to setup the gamepads in the cfg to read as player 3 and 4, I think this is done with Joypad-index in the cfg, but im not sure. Somebody more knowledgable may be able to elaborate.
            AndersHPA 1 Reply Last reply Reply Quote 0
            • AndersHPA
              AndersHP @Capeman
              @capeman But would this make the controllers useable for player 1 and 2?
              My thought was that generally the iPac is the preferred controller, but if some games play better on a gamepad, the players could just grab these instead.
              My Gameboy
                edmaul69 @AndersHP
                @andershp the ipac is a keyboard so there is no issues. I have an ipac2 and 6 controller setup. Players 1&2 controllers work at the same time as the ipac2
                • AndersHPA
                  AndersHP @edmaul69
                  @edmaul69 OK, cool - so it's perfectly doable. I just don't understand why I should hardcode gamepads for player 3 and 4. What have you done, do you have double inputs in the CFG files? input_player1= and input_player1_btn= ?
                  My Gameboy
                    edmaul69 @AndersHP
                    @andershp dont hardcode your controllers at all. You are using them as player 1&2.
                    • AndersHPA
                      AndersHP @edmaul69
                      @edmaul69 said in Maximum number of wired controller:
                      This is how I got the iPac to work, so it's the only way I know. I guess I'll find out once I have a gamepad in my posession.
                      My Gameboy
                        edmaul69 @AndersHP
                        @andershp yes you have to hardcode the ipac because its a keyboard. But the controllers will just work after you configure them in emulationstation.
                        • AndersHPA
                          AndersHP @edmaul69
                          @edmaul69 Oh, cool. Thought only player 1 was included in this initial controller setup.
                          My Gameboy
                            edmaul69 @AndersHP
                            @andershp if you have two matching controllers, just set up player 1's controller in emulationstation, then restart emulationstation and you will be good to go.
