    Problem with NDS emulators
    ndsdrastichelp
    3 Posts 3 Posters 1.0k Views
    • Y
      yopami
      I installed the Drastic emulator from the experimental package menu, but I do not see the NDS menu even though I have roms stuck in the folder. Does anyone know the reason for this?
      Regards, and thank you very much.
      • rbakerR
        rbaker @yopami
        @yopami https://retropie.org.uk/forum/topic/3/read-this-first
          Tsunami878
          Just use the default nds emulator from the experimental section and tone the resoulution down to as close to native as you can, native resolution for ds is 256x192. Got advance wars ds working smooth with minimal grafical errors when started with default settings it wouldn't run without lagging.
