    Snes Nes GBA roms wont load!!!
    snes romswont loadgbanes roms
    2 Posts 2 Posters 1.4k Views
    • L
      loop315
      I got a raspberry pi for xmas with retropie installed on it and a SNES usb controller. I loaded roms via sftp connection. The emulator ran fine for every game i tried for the snes. I then loaded alot of games into Nes, GB, GBC, GBA, and Megadrive. Once all the roms were loaded i could see them in each system. I tried them all, the only ones that would work were GB GBC and Megadrive. The snes wont run anymore they start to load and show a emulator config screen then boots back to the games list. What would cause roms that worked fine to stop loading once i added other roms to other systems?
      • markyh444M
        markyh444 @loop315
        @loop315 Which image are you using? What hardware are you on? Please read this as agreed on signing up to the forums https://retropie.org.uk/forum/topic/3/read-this-first and give us some more info.
        From your post, I can kind of deduce that as you got this Retropie "kit" for Christmas, that it was purchased with the SD card pre-loaded. That type of image is not something that the devs here will support and you'd be better downloading the official image and following the initial setup guide on the wiki.
        Retropie in a PSX - Pi3
