    YARMan Web (BETA)
    metadataeditorweb
    84 Posts 15 Posters 38.1k Views
    • daeksD
      daeks
      Just as a note here: I have rebranded the whole app with a more individual untaken name to avoid naming conflicts with other "web guis".
      The name will be "YARMan Web (Yet Another RetroPie Manager)"
        pjft @daeks
        @daeks I love it. :)
        • herb_fargusH
          herb_fargus administrators
          Looks brilliant. I'll have to find time test the latest changes though I'll defer to Jools for the setup script integration.
          daeksD 1 Reply Last reply Reply Quote 0
          • daeksD
            daeks @herb_fargus
            @herb_fargus said in Rebranded: YARMan Web (former RetroPie WebGUI) + Metadata Editor (BETA):
            Great :) - As a side note: Currently on each save in the metadata module, a backup copy will be done for the gamelist.
            General Questions:
            • What would be the location for videos / marquees? For the time being I am uploading everything to the emulationstation/downloaded_images location.
            • Whats the purpose of the thumbnail tag in the gamelist?
            • herb_fargusH
              herb_fargus administrators @daeks
              @daeks
              1. Seems like some people put them in diff folders /videos and /marquees but I think people use screenscraper to generate the gamelists on a PC, I'm not sure if we have defined a standard for retropie
              If you note the scraper module they can be put in the default location or in the ROM folder (which I'm more partial to as it means I only have to scrape once and they are in my backups with the ROMs) so it may be worth considering a setting for which folders/paths it saves?
              1. I don't know I thought it was to scrape a lower res image faster for the pi as it doesn't have the specs of a PC and full res images can slow it down?
                pjft @herb_fargus
                I'll second that.
                I certainly have the videos and marquees in a completely separate folder, for organization's sake. Also, as I load things from a USB, I don't want to store them in the SD card - which is the where the default scraper folder stores things.
                I know it's yet another small thing, but I would not object to having the user set the folders in a preferences tab. My structure currently is:
                /home/pi/RetroPie/roms/%SYSTEM_NAME%
                /home/pi/RetroPie/videos/%SYSTEM_NAME%
                /home/pi/RetroPie/marquees/%SYSTEM_NAME%
                /home/pi/RetroPie/roms/%SYSTEM_NAME%/images (as this was how it was by default, and I'm too lazy to redo all the gamelists by hand).
                I suppose I left the images folder insider the systems, but this way it's easier to manage. If I want, at any point in time, to have a lighter setup I can just ignore the videos folder, for instance.
                daeksD 2 Replies Last reply Reply Quote 0
                • daeksD
                  daeks @pjft
                  @pjft As I am not fixed on that as well, I will revert the path to be a common config parameter. I will move that to the fields definition itself on the next change with default pointing to emulationstation/downloaded_images.
                  Then its up to the installation later on which path will be used for uploading new media objects (common name I used for that).
                  Currently it is "static" in the defaults/config.json for all media objects (later on for each field with type "upload" in defaults/fields.json).
                  • daeksD
                    daeks @pjft
                    @pjft That would be my proposal for it: PR #21 Commit Diff
                    • daeksD
                      daeks
                      Anyhow, as the project progresses, I have applied some "standards" to it. The master branch is now protected and changes can only be applied by pull request if they are reviewed and checked against a modified version of the PSR2 coding standard.
                      Beside contributors, I think it would be nice to have some persons in place for testing changes and reviewing pull requests beside me before merging them.
                        J.Beau
                        Just reinstalled YARMan. Looking good! It doesn't display any emulators/roms at the moment. Is that correct?
                        • daeksD
                          daeks @J.Beau
                          @J.Beau yes you are right... I am testing with apache started with default "pi", but retropie starts the integrated server as root - sorry didnt know that :( - I updated the install script. Please retry it.
                            J.Beau @daeks
                            @daeks Worked! Just tested it with some Atari 2600 games. Started with an empty gamelist.xml. I was able to change one name, it doesn't seem to save any other changes after that. Uploading images doesn't work btw. Also, it doesn't use the gamelist.xml/images in the roms directory. They are also listed as roms. Not a problem, because I can move things over easily. I was doing everything manually anyway :) This looks very promising!
                            • daeksD
                              daeks @J.Beau
                              @J.Beau have you tested it only with safari? is it possible to try the upload in another browser?
                              I will test it with an empty gamelist :) haven't tried that. my fault.
                              gamelist.xml can be in the rom directory as well or have you changed anything? I am only aware of /home/pi/.emulationstation/gamelists as location. Interesting to see that images from the rom folder are listed as there is some extension white listing.
                                J.Beau @daeks
                                @daeks Tried it only with Safari. Emulationstation also reads gamelist.xml from the roms folder (/home/pi/RetroPie/roms/atari2600/gamelist.xml for example). I use this directory more because it is easier to move over romsets and their images and gamelist files :)
                                • daeksD
                                  daeks @J.Beau
                                  @J.Beau I believe the JQuery fileupload plugin has an issue with supporting safari. I will try to handle that and properly check compability.
                                  Beside that, I have uploaded a fix for the empty gamelist issue. I missed the "new entry" method in the save call :)
                                  Thanks for the clarification for the gamelist location. Currently it is "hardcoded" in a config file to emulationstation/gamelists. It can be modified later on.
                                  herb_fargusH J 2 Replies Last reply Reply Quote 0
                                  • herb_fargusH
                                    @daeks
                                    So just to clarify this whole gamelist thing:
                                    ES looks for gamelists in:
                                    [SYSTEM_PATH]/gamelist.xml
                                    ~/.emulationstation/gamelists/[SYSTEM_NAME]/gamelist.xml
                                    /etc/emulationstation/gamelists/[SYSTEM_NAME]/gamelist.xml
                                    Image/video/marquee paths can be anywhere as long as they are specified in the XML
                                    I'd have too look again at the scrapers to see where they default to
                                    • daeksD
                                      daeks @herb_fargus
                                      @herb_fargus thx. where exactly is system_path? in the rom folder?
                                      herb_fargusH A 2 Replies Last reply Reply Quote 0
                                      • herb_fargusH
                                        @daeks I'm pretty sure it's just the ROM path/home/pi/retropie/roms/system
                                          J.Beau @daeks
                                          @daeks said in Rebranded: YARMan Web (former RetroPie WebGUI) + Metadata Editor (BETA):
                                          Works now! Awesome! I'll test uploading with another browser tomorrow :)
                                            Arcuza @daeks
                                            @daeks If you need free LAMP hosting (from a Azure Stack licensed data center) for a cloud service, maybe I can help. I would love to see community interaction and game recommendations based on rom set and ratings.
