Hotkey Problems
I recently built the super game pi by using the tutorial on the adafruit website.
https://learn.adafruit.com/super-game-pi/overview
Everythng seems to work fine except all of my hotkeys. The exit game buttons work but the save state and load state do not. I have tried looking at the config file but I think it treats the controller as keyboard instead of a joystick. Can someone help me find where and what to change for the hotkeys using a keyboard? Most of the tutorials I find are for older versions of retropie and it seems the new one is quite a bit different.
@bassman6805
Look in the/opt/retropie/configs/all/retroarch-joypads/
directory and there should be a.cfg
file with your controller settings in it.For example I have a wireless Xbox 360 controller so mine is:
/opt/retropie/configs/all/retroarch-joypads/Xbox360WirelessReceiver\(XBOX\).cfg
In your version of that file you can put your hotkey settings. It will be in what looks like a random order.
I believe the ones for your controller will end with
_btn
https://github.com/retropie/retropie-setup/wiki/RetroArch-Configuration#hotkeys
Another example:
input_enable_hotkey_btn
is for controllers andinput_enable_hotkey
is for the keyboard.I have manually re-organized mine so I can read it easier but here is my hotkey section
# Hotkey button input_enable_hotkey_btn = "8" #Select # Exit emulator input_exit_emulator_btn = "9" #Start # Saves state input_save_state_btn = "1" #B button # Loads state input_load_state_btn = "2" #X button # Move to next save state slot input_state_slot_increase_btn = "5" #R button input_state_slot_increase_axis = "+0" #Right on D pad/Left Stick # Move back a save state slot input_state_slot_decrease_btn = "4" #L button input_state_slot_decrease_axis = "-0" #Left on D pad/Left Stick # Reset ROM input_reset_btn = "0" #A button input_reset_axis = "-1" #Up on D pad/Left Stick # Toggle RetroArch menu input_menu_toggle_btn = "3" #Y button # Volume controls: mute, volume up and down input_audio_mute_axis = "+1" #Down on D pad/Left Stick input_volume_up_axis = "-3" #Up on Right Stick input_volume_down_axis = "+3" #Down on Right Stick # Take screenshot input_screenshot = "7" #Right Trigger button
Determining Button Values
https://github.com/retropie/retropie-setup/wiki/RetroArch-Configuration#determining-button-values
