    nescasediybuildtheme
    1.3k Posts 210 Posters 3.2m Views
    • ruckageR
      ruckage
      Actually, don't worry Stuart. I've just double checked on mine and the black line is there as well (I just hadn't noticed it as most of the box art on mine was quite dark).
      I think its due to the scaling of the background image - it doesn't happen on the famicom-mini theme interestingly enough but that is setup differently.
      I'll work out a fix - it may just resolve if I scale the images to 1080p as I intend too but if not a small tweak in the xml files will fix it.
      EDIT: small adjustment to the boxart position in xml file seems to fix it so I will apply that to all systems affected.
      Stuart2773S 1 Reply Last reply Reply Quote 0
      • Stuart2773S
        Stuart2773 @ruckage
        @ruckage
        your a genius, can't wait to try the next update :)
        • ruckageR
          ruckage @Stuart2773
          @Stuart2773 said in Cardboard Mini NES + Nes mini and Famicom mini themes:
          @ruckage
          I'll hopefully have more updates sometime this weekend. I've been busy again but mainly just tidying up the theme so it's easier to work with and maintain. I've moved as much of the code as possible into the main nesmini.xml so that global changes are easy to do and I've created separate xml files for each of the box art sizes, many systems are using the same boxart size/shape so now if there is a problem like the black line above the boxart I only need to edit 1 file instead of 15.
          • ruckageR
            ruckage
            I've decide I will be scaling up the images to 1080p - I'd be very surprised if that wasn't the most commonly used screen res. The question is what scaling method should I use.
            Below is a picture comparing Nearest Neigbour and Hermite scaling, (I think it should display fullsize but if your not sure right click and select view image and if needed click on the image again to see at full size)
            Nearest Neighbour
            • Pro. Perfectly sharp pixels
            • Con. Pixels can vary in size (can be seen quite clearly on the gamelist border and the arrow)
            Hermite
            • Pro. Pixels appear to be uniform in size.
            • Con. Image looks a little softer
            Opinions would be appreciated as I'm quite undecided at the moment.
              dankcushions Global Moderator
              not sure if i'm reading these last few posts right but FYI emulationstation already applies some sort of subtle smooth scaling on the pi. if you're only testing on windows you won't see it i guess!
              @Rookervik 's pixel theme has a similar style and i think it has small source images. looks crisp here!
              ruckageR 2 Replies Last reply Reply Quote 0
                momaw27
                Nearest Neigbour all the man!
                For a pixel theme I think sharp pixels are a must!
                • ruckageR
                  ruckage @dankcushions
                  @dankcushions
                  Thanks for the reply, I'll test it and see(I thought it applied a bilinear filter?) but the problem I was having was there was some ugly scaling artifacts I was trying to eliminate.
                  • ruckageR
                    @dankcushions said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                    I was wrong, I just did a test and contrary to what I thought it actually appears to do nearest neighbour scaling but the scaling artifacts still appeared with the low-res images. Its not easy to see on busier backgrounds but as this theme has large areas of single colours it's more apparent think.
                    Thanks anyway, it was worth checking.
                      robertybob
                      Are any of these themes going onto Github? Would love this to be added to RetroPie too :)
                      ruckageR 1 Reply Last reply Reply Quote 1
                        postmangav
                        This is incredible! Sorry if this has been asked before but where do you get the HDMI cable which screws onto the back of the machine from? I really like how neat they make projects look but have never known where to find them. Don't even really know what to search for to be honest! Great project dude :)
                        • ruckageR
                          ruckage @robertybob
                          @robertybob said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                          Maybe, though I've never used Github so I'll have to look into it.
                          @postmangav said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                          Thanks :). I bought the HDMI panel mount from ebay.
                          Here is the link to the one I bought: HDMI Panel Mount
                          There are cheaper ones but this one had a shorter cable which was ideal for my project. I did strip off the plastic sheath on the cable to make it slightly more flexible.
                          • ruckageR
                            ruckage
                            I really wasn't happy about the image scaling at 1080p so I took the plunge and re-made everything at a resolution of 480x270 which scales cleanly to 1920x1080. I really wasn't sure how it would look but I'm quite pleased with it. I've redone the graphics for both themes but have only started editing the famicom-mini theme xmls so far.
                            There are few benefits to this change:
                            • Slightly longer game names will be displayed without being cropped
                            • The game description window is a bit bigger.
                            • The low-res images can be used as they should hopefully scale to 1080p now without any artifacts. This should reduce the amount of GPU memory needed which has been a problem in the past when using lots of systems (I think that has been fixed now but I still think it's good to save memory)
                            Here's a screen capture of how it looks.
                            I wanted to keep the number of entries in the game list as an odd number so that the selection bar is in the middle when scrolling so I decided to stick with 7 names displayed at a time. As this left more space at the top and bottom of the list I have drawn some new larger arrows to use a little more of that empty area.
                            Stuart2773S 1 Reply Last reply Reply Quote 4
                            • Stuart2773S
                              Stuart2773 @ruckage
                              @ruckage
                              that looks pretty good :)
                              • ruckageR
                                ruckage
                                Here's a mockup of the 1080p version of the nes-mini theme (based on the famicom-mini capture). The arrows are simpler than the famicom version to fit the style and are coloured red now so I have some of the red on dark blue as seen on the real nes classic menu.
                                R 1 Reply Last reply Reply Quote 3
                                  runik @ruckage
                                  @ruckage So impressive , I cannot wait to see the SNES , Super Famicom Themes you are planning :)
                                  ruckageR 1 Reply Last reply Reply Quote 2
                                    momaw27
                                    Oh yeah!!!
                                    Looking great!
                                    Do you have your next release planned yet?
                                    • ruckageR
                                      ruckage @runik
                                      @runik @momaw27
                                      Thanks for the replies.
                                      I will have a new update soon but bear with me as I've created more work for myself with the conversion to a 1080p optimized theme as I will have to remake all of the backgrounds - it shouldn't take too long but I want to get both themes up to the same point and then I will add some more systems. I've already drawn logos for GBA and SNES so they will definitely be next.
                                      Sadly there is a downside to my change to 1080p and that is that the theme unfortunately no longer displays correctly at 720p as the the gamelist doesn't line up correctly - even though technically it should. I believe this is due to a bug within ES itself as Ive had lots of problems with textlists (a good example is that if you alter the line spacing for a textlist the selector bar no longer lines up with the text - that was a big headache on my theme.)
                                      However if a 720p version is desperately wanted by lots of people then I'm sure I can sort something out, but to be honest I think 1080p is far more popular anyway.
                                      Stuart2773S 1 Reply Last reply Reply Quote 2
                                      • Stuart2773S
                                        Stuart2773 @ruckage
                                        @ruckage
                                        just wandering if you created a new SVG for the famicom version?
                                        • ruckageR
                                          ruckage @Stuart2773
                                          @Stuart2773
                                          Yep, already done one.
                                          Regarding the SVG logos - I think I'm going to switch to PNG as I think they look better than the SVGs for pixel art (no antialiasing so sharper). It may also possibly speed up loading of the theme as all images for this theme will now be very small PNG files.
                                            momaw27
                                            Cool. The slow load time is something I've noticed as well. Hopefully (and most likely) the smaller file sizes will fix the problem!
