    nescasediybuildtheme
    1.3k Posts 210 Posters 2.7m Views
      jcook84 @ruckage
      @ruckage
      Thanks for all your hardwork! How did you achieve the glowing effect in the Vectrex theme? I've been hacking it up and adding it to other themes from your v1.3 build
      http://imgur.com/P4CGXuV
      http://imgur.com/38XDT3m
      ruckageR 1 Reply Last reply Reply Quote 1
        arcane
        This is an excellent theme. Is there any chance of having the ports menu and the sega game gear themed in the next update?
        • fellegF
          felleg
          Awesome work @ruckage , can't wait to try the new versions out! :) Just for the sake of communications, I had two quick suggestions for you that would allow us to better follow this project:
          1. Have you made a to-do list of the upgrades you want to add to the theme (new systems, configs, various options, etc.)? If you did, maybe add it to the readme.txt and keep it updated. This should help us follow this project much better than searching posts in this (huge) thread. :)
          2. I see you linked this thread in the readme.txt as the place to follow development of this theme. Good idea, however the OP of the thread is completely out of date with where the project is headed now. Just a suggestion, but if you agree, maybe give a quick edit to the OP to say that the theme is now the main focus of the thread, instead of the cardboard nes mini. ;)
          • ruckageR
            ruckage @jcook84
            @jcook84 said in Cardboard Mini NES + Nes mini and Famicom mini themes:
            @ruckage
            Glad you're having fun with it :) There are several ways to create the glowing effect but I did it by duplicating the layer in photoshop and then applying a Gaussian blur to the duplicated layer. You'll like the Virtual boy system I'm currently working on as that also features a glow effect. I'm also working on more style options for the famicom-mini theme and at least one of those will be glowy :)
            @arcane said in Cardboard Mini NES + Nes mini and Famicom mini themes:
            Game Gear has been themed for ages (it was one of the first systems added to the theme). Ports is on the list and will probably be in the next batch of systems I'm working on.
            @felleg said in Cardboard Mini NES + Nes mini and Famicom mini themes:
            Good points. I do have a request list of systems but it's buried way up in this thread: Click Here (I do edit it as I add new systems).
            What I'll perhaps do is add theme information (request list, download etc.) to the top of the first post so it's easy to find. Does that sound like a good idea?
            A fellegF 2 Replies Last reply Reply Quote 0
            • ruckageR
              ruckage @arcane
              @ruckage
              As you seemed to like the arcade background, here's a version of it with a subtle glow effect.
                arcane @ruckage
                @ruckage Whoops! I meant the atari lynx not the game gear.
                  jcook84 @ruckage
                  @ruckage
                  Awesome! I should be able to figure out the effect in GIMP, or I can switch colors around on the arcade theme you just posted. Thanks again for everything!!!!
                  • OmnijaO
                    Omnija
                    ever thought of modifying the theme to make it less like the original theme and more like the official console?
                    https://postimg.org/image/bbr7ntwqz/
                    (Rough draft)
                    Would open more doors to customization towards plugs and via view towards console look a like instead of background decoractions.
                    Systems: Raspberry Pi 2
                    Overclocked: 1050 | 525 | 350 | 425 | 256
                    My Themes: Metro Theme | Simpler Turtlepi | Future Mini
                    S ruckageR Stuart2773S 3 Replies Last reply Reply Quote 0
                      Syhles @Omnija
                      @Omnija
                      Are the two controller ports down at the bottom for number of players?
                      • ruckageR
                        ruckage @Omnija
                        @Omnija said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                        Would open more doors to customization towards plugs and via view towards console look a like instead of background decorations.
                        I've considered making console specific borders ( a lot of work with all the systems on retropie) and I've also considered moving away from the nes border completely to a more generic border but I think a lot of people would be upset if I did that. For now at least things will remain as they are.
                        I can't keep going back and re-doing everything as it's a huge amount of work and the theme would never progress. I've already made at least 2 major but necessary revisions to the entire theme (first when I switched from 720p to 1080p and the last update where the layout was changed) and it takes days of work. Not to mention I could never keep everyone happy as much as I try to as everybody has there own opinion of how things should look.
                        I'm personally quite pleased with the look of the theme now, I may update the odd system here and there that I feel could be improved but most systems will remain as is. I am adding several new styles to the famicom-mini theme which will feature different borders though so that combined with all the different layouts provides lots of options.
                        • Stuart2773S
                          Stuart2773 @Omnija
                          (Rough draft)
                          did you see this post :- ?
                          https://retropie.org.uk/forum/topic/8391/cardboard-mini-nes-nes-mini-and-famicom-mini-themes/197
                          OmnijaO 1 Reply Last reply Reply Quote 0
                          • OmnijaO
                            Omnija @Stuart2773
                            @Stuart2773 No, i haven't seen that yet. Has it been released?
                            Stuart2773S 1 Reply Last reply Reply Quote 0
                            • Stuart2773S
                              Stuart2773 @Omnija
                              no its not released, its a dual image im currently working on that runs emulation station & attract mode its only going to support NES, FAM, FDS.
                              ive updated the original post, and heres some screens of the attract mode WIP version:-
                              0_1492880101532_2.JPG 0_1492880109939_3.JPG 0_1492880116714_4.JPG 0_1492880121680_5.JPG
                              all fully animated menus with working icon buttons
                              ruckageR 1 Reply Last reply Reply Quote 2
                              • ruckageR
                                ruckage @Stuart2773
                                @Stuart2773
                                From the readme included with my themes as your post implies you are modifying my ES theme:
                                License
                                This theme is being actively developed, a great deal of work has been put into the theme so please do not use the graphics I have created in other projects (with the exception of any graphics that are an exact copy of of those from the real 'NES classic'/'Famicom mini' menu).
                                You are free to modify the theme for your personal use only - please do not share modified versions of this theme.
                                Obviously the attract mode version isn't a problem as that isn't using my ES theme as a base, providing you aren't using any of the graphics/logos that were drawn by myself. (Hasn't someone already made an attract mode NES/famicom theme though?)
                                Finally if you want to promote your own theme you should do it in a separate topic.
                                Stuart2773S 1 Reply Last reply Reply Quote 2
                                • Stuart2773S
                                  Stuart2773 @ruckage
                                  @ruckage
                                  No need to worry, I have no plans on releasing this image theme as it's just modified for my own personal use, I just wanted to show @Omnija what can be achieved if he wanted to make a theme more true to the original nes mini.
                                    G30FF @ruckage
                                    @ruckage Seconding the Virtual Boy, 32X, Ports, Dosbox/PC, and Kodi. I do have a somewhat non-standard request though.
                                    The Pixel theme offers support for TurboGrafx-CD/PC Engine CD (tg-cd and pce-cd respectively). Would it be possible to get that in your themes?
                                    • fellegF
                                      felleg @ruckage
                                      @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                      Sounds like a good idea to me! :) Any way that communicates information clearly without much search is a win in my book.
                                        momaw27
                                        @ruckage Been using your theme from day one and LOVE it and all the improvements you've made!
                                        I recently made the move to an oldschool 4:3 tube tv for my retro gaming and discovered your wonderful theme doesn't quite make the transition into 4:3...
                                        As I was staring at my tv I realized that if we got rid of the metadata, your theme would be perfect for the 4:3 ratio.
                                        Any chance your (or someone with more knowledge than myself) could try a 4:3 version?
                                        Thanks again for your SWEET theme!
                                        Beau
                                        fellegF ruckageR 2 Replies Last reply Reply Quote 0
                                        • fellegF
                                          felleg @momaw27
                                          @momaw27 said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                          Beau
                                          +1 for a 4:3 version of the theme
                                          • ruckageR
                                            ruckage @momaw27
                                            @momaw27
                                            @felleg
                                            The theme is designed specifically to work at 1080p and it will have problems at any other resolution. However at some point I'd like to convert it to a 4x3 resolution but it's a lot more work than you perhaps realise. I won't even attempt it until the theme supports the majority of systems as maintaining several different themes at once takes a lot of time so it would be better to convert everything in one go.
                                            Next problem is what resolution to target? There are lots of 4x3 resolutions and due to an ES bug with game lists I unfortunately can't just do a 'one size fits all' solution as the game list will only line up correctly with my art at the specific resolution I target.
                                            I could maybe have an option in the xml that you would have to edit to enable it to load pre-configured settings for several different 4x3 resolutions but ideally I would still like to know the most popular that would be used as a default setting so it works for most users out of the box. (Does retropie default to any specific 4x3 resolution when connected to a 4x3 monitor or TV?)
                                            fellegF TMNTturtlguyT 2 Replies Last reply Reply Quote 0
