    nescasediybuildtheme
    1.3k Posts 210 Posters 3.2m Views
    • I
      i5rael_lp @wmarcio
      @wmarcio said in Cardboard Mini NES + Nes mini and Famicom mini themes:
      This happened after updating the emulationstation, I had this problem, the solution was to go back to the previous version.
      could you help me with any link to do that? can't find anything, don't know how to look up for it (english is not my first language). Thanks!
      EDIT: I couldn't rollback the ES version, but I did managed to mod ruckage theme. Edit the nesmini.xml and add "pos/size" (in bold text)
      Hope this helps!
      CC. @Run @ruckage
      <textlist name="gamelist">
      <forceUppercase>0</forceUppercase>
      <scrollSound>./sounds/se_sys_cursor.wav</scrollSound>
      <fontPath>./art/NESCyrillic_gamelist.ttf</fontPath>
      <alignment>left</alignment>
      <horizontalMargin>0.0083333333333333</horizontalMargin>
      <pos>0.2959 0.2035</pos>
      <size>0.4085 0.6</size>
      <fontSize>0.0592592592592593</fontSize>
      </textlist>
      wmarcioW 1 Reply Last reply Reply Quote 1
      • wmarcioW
        wmarcio @i5rael_lp
        @i5rael_lp said in Cardboard Mini NES + Nes mini and Famicom mini themes:
        Hope this helps!
        Great solution, I'll try it to see if it works for me.
        Thanks.
        Post the feedback in a little while.
        • Y yewox50273 referenced this topic on
        • wmarcioW
          wmarcio
          It worked, but sometimes the emulationstation breaks, and you need to restart and hope to work.
          The best solution for now is to mount the original retropie image (version 4.7.1) and go to the folder \opt\retropie\supplementary\emulationstation
          and copy the files and replace in the folder with the problem version, which is in the same place on the sd card.
          You need root privileges for this, you can copy over the network.
          That's the way I found it, if someone knows it easier, just teach us.
          To make life easier for all of us, here are what you need:
          https://we.tl/t-pbcGp8sxVu
          https://www.mediafire.com/file/57ppn52d39tch1u/5977-8AAB.zip/file
          I'm not a Linux expert, just learning the basics.
          Y 1 Reply Last reply Reply Quote 0
            gpeds
            Hi, I run the snes-mini-master theme and ran into this issue when i updated everything. To fix the layout issue I removed the background images on the game list ( it removes the boxes around the game names). I think it actually looks less busy and cleaner on my setup.
            I edited the following part out by commenting out these sections in this file es-theme-snes-mini-master/layouts/setup.xml ( around line 85 or so ):
            		<image name="gamelist_background" extra="true">
            			<path>./../art/gamelist_background${wide}.png</path>
            			<size>0 0.7333333333333333</size>
            			<origin>0.5 0.5</origin>
            			<pos>0.5 0.5</pos>
            			<color>4d4d4d9a</color>
            		</image>
            		<image name="gamelist_outline" extra="true">
            			<path>./../art/gamelist_outline${wide}.png</path>
            			<pos>0.5 0.5</pos>
            			<color>ffffffbe</color>
            			<zIndex>200</zIndex>
            		</image>
            maybe on the theme you are using you could do something similar to remove the box surrounding the list of games
            wmarcioW 1 Reply Last reply Reply Quote 0
            • Y
              yewox50273 @wmarcio
              Yes it segfaults and crashes, and the same behavior is happening with the SNES-mini theme.
              • wmarcioW
                wmarcio @gpeds
                @gpeds would you be able to post the result with a photo?
                • S sleve_mcdichael referenced this topic on
                • mituM mitu referenced this topic on
                • mrmadcatzM
                  mrmadcatz
                  @mitu Here are the images, as requested:
                  SNES:
                  NES:
                  I also created, copied and renamed background files in each necessary directory to go along with these:
                  background/bg_tron/auto-random.png
                  background/bg_tron_blur/auto-random.png
                  background/bg_tron_blur_usa/auto-random.png
                  background/bg_tron_usa/auto-random.png
                  background/blurred_shots/auto-random.png
                  background/nes_mini/auto-random.png
                  • mrmadcatzM
                    mrmadcatz
                    This is the last update (I felt I could get the icons even closer to the style of ruckage's originals, and believe that I have). Here are ALL of the assets I've adjusted for the ruckage/es-theme-snesn-mini theme for RetroPie. This includes backgrounds, labels and icons for the auto-random list that goes with all the different configurations of this theme that are available by editing config.xml that comes with the theme. They are as follows:
                    Icons
                    es-theme-snes-mini/art/icons and es-theme-snes-mini/art/icons_usa
                    es-theme-snes-mini/art/nes_icons and es-theme-snes-mini/art/nes_icons_usa
                    Logos
                    es-theme-snes-mini/art/logos and es-theme-snes-mini/art/logos_usa
                    Backgrounds
                    es-theme-snes-mini/background/bg_tron/auto-random.png
                    es-theme-snes-mini/background/bg_tron_blur/auto-random.png
                    es-theme-snes-mini/background/bg_tron_blur_usa/auto-random.png
                    es-theme-snes-mini/background/bg_tron_usa/auto-random.png
                    es-theme-snes-mini/background/blurred_shots/auto-random.png
                    es-theme-snes-mini/background/nes_mini/auto-random.png
