    nescasediybuildtheme
    1.3k Posts 210 Posters 3.2m Views
    • MikOzzZM
      MikOzzZ @ruckage
      hi @ruckage think you add some missing systems to your minines theme like "amstrad, atari st, amiga, msx, gw, pcenginecd, scummvm"?
      Thank you for your answer
      • H
        hi-ban
        Hi!
        I noticed the SNES icon was quite flat compared with the other console icons, so i changed some stuff and added additional details. Here is the result next to the original one:
        Old SNES: original New SNES: modified
        New SFC: New SFC
        ruckageR 1 Reply Last reply Reply Quote 4
        • ruckageR
          ruckage @hi-ban
          @hi-ban
          You're right the original is a bit flat, probably as it was one of the first I did and hadn't settled into a style at that point.
          I really want to keep this all my own work though but I may go back to the icon (and a few others) and update them myself.
          • ruckageR
            ruckage
            I've updated the snes icon myself so that it has more depth, It will be in the next update (I'll probably update pc engine at some point as that is also a bit flat.)
            @hi-ban your modifications to my icon look just as good as mine but as I said I'd just like to have all the art on this be my own work, I hope you understand.
            H 1 Reply Last reply Reply Quote 4
            • H
              hi-ban @ruckage
              @ruckage No probs, man.
              • HAILtoSTARSCREAMH
                HAILtoSTARSCREAM @ruckage
                This post is deleted!
                • N
                  Necro
                  I've migrated over to this theme and hit a few systems that aren't included that seem semi-popular. (Or, at least, I have :)). Wondering if there's any chance to get them added? (I know you want to do all art yourself, otherwise I would try myself! :) )
                  • Game & Watch
                  • TurboGrafx-CD
                  • SuprGrafx
                  • ruckageR
                    ruckage @Necro
                    @necro
                    Hi. Yes those are on my to do list. Now my Snes theme is released and more or less parallel with this theme I will get back to adding the missing systems. I'll also be adding a default theme so that at least then it will still work correctly if a system is missing.
                    N 1 Reply Last reply Reply Quote 1
                    • N
                      Necro @ruckage
                      @ruckage Great - I was thinking about that 'default' system idea as well. Also, semi-related (was coming back to edit my comment - damn you're fast) - is there a US SNES icon floating around to switch to? I thought I saw one in the thread but...not being able to search the thread is making things difficult.
                      • ruckageR
                        ruckage @Necro
                        @necro
                        Yeah, if you check in the theme folder and go to the snes folder there is an alternate in there, you have to change it manually - just rename it to carousel_logo.png.
                        I've automated it via the config file on the Snes-mini theme and I'll see about doing the same on the Nes-mini theme in a future update.
                          A Former User
                          For the Arcade image, it has 10p. Is there a chance to get one that has 25 cents(cent symbol) for US users?
                          Thanks as always! :)
                          • HexH
                            Hex
                            @ruckage it has been a long time hence asking, any eta on DOSBOX and PAL suppot?
                            • ruckageR
                              ruckage @A Former User
                              @livefastcyyoung said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                              Here you go :)
                              ? 1 Reply Last reply Reply Quote 2
                                A Former User @ruckage
                                @ruckage Yr the best! :)
                                • ruckageR
                                  ruckage @Hex
                                  @hex said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                  I plan on getting the resolution support working for the SNES theme next and will get the Pal resolution added to the Nes theme around the same time. After that I'll get back to work on the missing systems, it will be Amiga, MSX, MSX2, and PCengine cd first as I've already made icons for those and I will the do DOS and ScummVm shortly after as I know both of those are popular.
                                  • N
                                    Necro
                                    Everyone's not clamoring for Game and Watch? I'm freaking shocked. :)
                                    Is there an official (or unofficial) set of loading screens or a 'boot' screen for this theme as of yet? I tried to scan the thread but am having some problems. If so, having it posted in the first post would be GREAT.
                                    (And keep up the good work Ruckage!)
                                      A Former User @Necro
                                      @necro If you are looking for launching images, those were done here...
                                      https://retropie.org.uk/forum/topic/11481/nes-mini-theme-launching-images
                                      • N
                                        Necro @A Former User
                                        @livefastcyyoung Thanks much - searched a few times and for some reason couldn't find the launch images it at all.
                                        • ruckageR
                                          ruckage
                                          Hi everyone,
                                          I've been busy this weekend and have just updated the nes-mini theme with several new systems, custom-collections, an alternate snes-usa system, and also updated the help images to match the current ES button functions.
                                          The new systems are:
                                          PC/dosbox
                                          Amiga
                                          Game & Watch
                                          PC engine CD
                                          MSX
                                          MSX2
                                          Custom-collections
                                          snes-usa
                                          Below is an animated GIF showing the new additions.
                                          PokeEngineerP A HAILtoSTARSCREAMH 4 Replies Last reply Reply Quote 6
                                          • PokeEngineerP
                                            PokeEngineer @ruckage
                                            @ruckage
                                            Nice!
                                            Don't sweat it.
