    nescasediybuildtheme
    1.3k Posts 210 Posters 3.2m Views
      dudumaroja
      this theme is amazing.. thankyou very much @ruckage ...
      i have two sugestions.. some system should get a new background image.. some are simple boring next to others.. like nes and atari.. just plain boring color.. next to master system and mega drive. they look ugly
      and the other sugestion whould be a set of borders to use as overlay to match the theme.. it whoukd make the retropie look even better
      • matchamanM
        matchaman
        I need help setting up a custom layout.
        I am messing with 4x3setup.xml (for a 4:3 CRT monitor) and I can't get it done like that:
        I don't need the "rating/played/player" bar at the bottom of the artwork, I'd like a single "genre" banner instead like in the mockup I made above.
        • johnodonJ
          johnodon
          Will PSP Minis be added as a separate system?
            A Former User @johnodon
            @johnodon He's said a handful of times he had no plans for separating them.
            • ShadeofDanteS
              ShadeofDante
              Quick question: Loving the theme, nothing but amazing work. I'm using the NES mini theme, trying to get the SNES logo to the USA type. I found the folder that has the proper files in it, thought I'd be able to edit a config file to make it US type.
              Is there something I'm missing to use the purple colored SNES logo vs the JP/EUR one?
              matchamanM 1 Reply Last reply Reply Quote 0
              • matchamanM
                matchaman @ShadeofDante
                @shadeofdante said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                Just rename the folder :)
                • F
                  fefitohh
                  Hi ruckage!
                  Thanks for your theme it is wonderful.
                  Is it possible to add background music to the main menu?
                  Are you going to update this theme?
                  • ruckageR
                    ruckage
                    Just re-name the image files in the folder, currently there is no option to change it from the config file.
                    @fefitohh said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                    Hi ruckage!
                    There are no built in was to add music but the are ways it can be done, see here: https://retropie.org.uk/forum/topic/347/background-music-continued-from-help-support/44
                    I will update the theme but I've just been busy, I have a few other themes I also work on as well as my own projects and recently have had no time with Christmas coming up.
                      Skainlurmis @matchaman
                      @matchaman Hey there, I'm trying to do the same thing (rename SNES) and it's not letting me change anything. I'm getting permission denied and all that. I'm trying to find how to fix it all, but I'm losing the thread. Is it easier than I am making it out to be?
                      • matchamanM
                        matchaman @Skainlurmis
                        @skainlurmis said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                        You probably don't have permissions, you need to modify files as root.
                        Here are some basic instructions:
                        • sergioadS
                          sergioad @Malixx
                          @malixx could you remake your splashscreen with a louder sound? It is awesome as it is but it sounds a little muted on my pi compared to the UI sounds and I want uniformity
                            darklordzach
                            @ruckage Hey could you add wii, gamecube, wii u and 3ds please?
                            HyruleslinkH ruckageR 2 Replies Last reply Reply Quote 0
                            • HyruleslinkH
                              Hyruleslink @darklordzach
                              @darklordzach Hmm. I am genuinely curious why people ask for these systems that aren't playable on a Pi...
                              AnalogHeroA 1 Reply Last reply Reply Quote 0
                              • AnalogHeroA
                                AnalogHero @Hyruleslink
                                @hyruleslink There may be support for these systems under the win version of ES.
                                  Altieres Lima
                                  @darklordzach said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                  Download: https://mega.nz/#!7RJRDArK!DBC5TpO4_nJsCNL-uQwG5ramcJUwLbgsEnMMkFXvsI8
                                  Download: https://mega.nz/#!GEZl0ZTb!Lnga727qqncRF-W5-w2UPN8QsFo6wv03WUIkfEGjNWY
                                  https://mega.nz/#!XJglDZxA!Q-RzVFzkDlHtOPqYRWONc2_lTAojLPIk1u4zFG1dwqk
                                  • ruckageR
                                    ruckage @darklordzach
                                    These systems are not a priority as they are not supported by retropie.
                                    • herb_fargusH
                                      herb_fargus administrators @ruckage
                                      @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                      ...on the pi ;)
                                      • N
                                        Necro @Altieres Lima
                                        @altieres-lima What font/templates are you using for those? Would like to throw together a few for systems (SuperGraphx, Scumm, TGCD) that are on the to do list as a temporary fix.
                                          Altieres Lima @Necro
                                          @necro, I found on Google pixel videogames.
                                          • ruckageR
                                            ruckage @Altieres Lima
                                            @altieres-lima
                                            Hello. Can you please not share modified versions of my theme.
                                            License
                                            This theme is being actively developed, a great deal of work has been put into the theme and art so please do not use the graphics I have created in other projects (with the exception of any graphics that are an exact copy of of those from the real 'NES classic'/'Famicom mini' menu).
                                            You are free to modify the theme for your personal use only - please do not share modified versions of this theme.
                                            Commercial distribution is prohibited
                                            A 1 Reply Last reply Reply Quote 3
