    ARE VICE C64 MACHINE PRESETS POSSIBLE ?
    c64 vicedefault setting
    2 Posts 2 Posters 788 Views
      dunnieboy
      I am a noob. Just had to state that before getting into this post. =/
      Question : Everytime I launch a game ... I find myself going into the VICE Machine settings to set the joystick config.
      Is there a way to set a VICE preset so the default is what I typically use ?
      Thanks !
      D
        edmaul69 @dunnieboy
        @dunnieboy i dont have my pi to tell everything exact. After you set your controllers up back at the main menu i believe you go into the bottom option. If you go in there you can set save on exit and you can save your joystick config in there too. I think its in there where the option to set the menu button to the controller too.
