    Pi3 Retropie USB powered audio
    audio issuesusb powerretropie 4.1
    3 Posts 3 Posters 1.7k Views
    • E
      Emmuss
      Hi folks,
      i got my retropie setup up and running but if i plug my usb powered arctic speakers in i hear a frequently cracking with about 200ms delay.
      pi power: Raspberry Pi Foundation official 2.5A power supply
      arctic speakers: https://www.arctic.ac/de_de/s111.html
      could this be caused by low power?
      • E
        EctoOne
        Does it still uses the headphone jack to get the sound? If so, the quality on it is pretty bad. I used it as well because I wanted to use headphones in Kodi even when my TV was off. And I also didn't want to spend like 200€ for an Av Receiver, so I bought a cheap usb soundcard. Sound is still not perfect (gets bad when I move files to my external USB drive) but it's way better than the build in jack.
          backstander @Emmuss
          @Emmuss
          From the command prompt
          List all USB devices
          lsusb
          cat /proc/asound/modules
          Set "card #1" as the default audio device
          sudo nano /etc/asound.conf
          pcm.!default {
           type hw card 1
          ctl.!default {
           type hw card 1
          Disable HDMI audio
          sudo nano /boot/config.txt
          #hdmi_drive = 2
          RetroArch audio fix
          /opt/retropie/configs/all/retroarch.cfg
          audio_device = "<name of USB audio device>"
          Test audio
          aplay -l
          More info here:
          https://learn.adafruit.com/usb-audio-cards-with-a-raspberry-pi/updating-alsa-config
