    Reicast - Xbox 360 Wireless Controller - Wrong emu.cfg?
    reicastxbox 360controllerwirelessemu.cfg
    1 Posts 1 Posters 764 Views
      GoodOneSam
      hi guys,
      I've been trying to map my controller for reicast with my xbox 360 wireless controller for the past 3 days and finally gave up. Ended up uninstalling everything. So tonight i decided to give it another go, reinstalled Reicast, and added a game.
      For some unknown reason, the controls i wanted to map the way I wanted, is all configured without me doing ANYTHING. All I did was just reinstall Reicast back, I made sure I deleted all files as well when I uninstalled it. Now I'm trying to add a 2nd controller but my emu.cfg looks different from all the ones I've seen. Please see below.
      [audio]
      disable = 0
      [config]
      Debug.SerialConsoleEnabled = 0
      Dreamcast.Broadcast = 4
      Dreamcast.Cable = 3
      Dreamcast.RTC = 1543276800
      Dreamcast.Region = 3
      Dynarec.Enabled = 1
      Dynarec.idleskip = 1
      Dynarec.unstable-opt = 0
      aica.LimitFPS = 1
      aica.NoBatch = 0
      aica.NoSound = 0
      bios.UseReios = 0
      pvr.MaxThreads = 3
      pvr.Subdivide = 0
      pvr.SynchronousRendering = 0
      pvr.rend = 0
      rend.UseMipmaps = 1
      rend.WideScreen = 0
      ta.skip = 0
      [dispmanx]
      height = 480
      maintain_aspect = yes
      width = 640
      [input]
      evdev_device_id_2 = -1
      evdev_device_id_3 = -1
      evdev_device_id_4 = -1
      [omx]
      audio_hdmi = yes
      audio_latency = 100
      [reios]
      ElfFile =
      [testing]
      ta.HashCheckFile =
      ta.HashLogFile =
      It looks like it hasn't been changed or anything, but yet my controller works just fine. I know originally the exit button would be the Xbox logo button, but I had configured it before to Select. Anyone know how this happened or how I can edit this to add a controller?
      Thanks in advance!
      [validate]
      OpenGlChecks = 0
