    Stephen Selph's Scraper Not Working for TI-99/4A
    ti99 scraper
    3 Posts 2 Posters 606 Views
    • 9
      99er
      Hi-
      I'm using Stephen Selph's scraper to scrape my systems, and it's working great except for the TI99. The TI is an 'experimental package'. Is that why it's not being scraped? I've tried selecting only the TI to be scraped, but no luck. Googling around a bit, I see that there should be a TI99 folder with a file named gamelist.xml located at /home/pi/RetroPie/roms/ and also at /home/pi/.emulationstation/gamelists/.
      Neither of those locations has a TI99 folder on my system. Other than creating those folders and files manually, what can I do?
      Thanks,
      Rich
      www.99er.net
      The TI-99/4A Home Computer Page
      • herb_fargusH
        herb_fargus administrators @99er
        @99er it's obscure enough that it isn't supported. Either create them manually or post a topic on sselphs GitHub for inclusion.
        You'd have to help provide hashes for games though etc
        • 9
          99er
          @herb_fargus said in Stephen Selph's Scraper Not Working for TI-99/4A:
          sselphs GitHub
          Ah! Ok- that's what I was wondering. I've gone ahead and posted a request to add it on sslephs GitHub (guess I should have started there...). Thanks for the quick response!
          Rich
          www.99er.net
