    Android compatible Controller working for Retropie?
    bluetooth contrcontroller conandroid
    2 Posts 2 Posters 1.1k Views
      Bebesiege
      http://www.ebay.de/itm/PELTEC-Bluetooth-Controller-Gamepad-Amazon-FireTV-TV-Box-Smart-TV-/332099406507?_trksid=p2141725.m3641.l6368
      here is a controller which can be used with Amazon FireTV Chrome stick and Android tablets.
      It is quite cheap and has good ratings i would like to use it with my retropi raspi 3
      Is this automatic compatible with Retropie since it runs with Android Linux?
        dikdom
        I have a similar controller (mine is red and black). I wouldn't say it is automatic compatible. I configured for retropie months (a year?) ago, and as I remember I had to restart the bluetooth registering procedure several times until the controller was recognized by the Pi3.
        After that it was OK for me. Well, I had some issues with vice (C64), but when I figured it out and fixed it (my mistake) I could - and I'm still able with the latest Pi - play with my C64 games.
        Emulationstation menu is also ok.
        And the twist:
        a couple of days ago I wanted to try out some other games (PSX, and gamesandwatch) and it seems that there are some mapping issues. I can't find the reason, I guess it is just again some configuration glitch... Still investigating.
