    I need help booting Retropie
    helpretropie 4.2
    15 Posts 4 Posters 2.3k Views
      AwesomeAzzy
      When I try booting retropie, it always boots up raspbian, why does this happen, there's no sign of emulationstation/retropie whatsoever. Even after formatting my sd card multiple times, nothing changes. This happens when trying to boot Version 4.2.
      • AlexMurphyA
        AlexMurphy Banned @AwesomeAzzy
        @AwesomeAzzy Do you mean it is just booting to the command line / terminal?
          AwesomeAzzy @AlexMurphy
          @AlexMurphy No, it just boots up the raspbian gui normally, even though I wrote the retropie img to the sd card
          AlexMurphyA cellyC 2 Replies Last reply Reply Quote 0
          • AlexMurphyA
            @AwesomeAzzy The official RetroPie image does not come with the PIXEL desktop installed. What you are saying is impossible. Unless of course you are using a third party pre-configured image. In which case I'm not able to assist you.
            • cellyC
              celly @AwesomeAzzy
              @AwesomeAzzy are you trying to write the image over a NOOBS install? Make sure to format your card using a good progam like this, then write the retropie image to the sd card.
              Currently Playing: Tetris (Gameboy)
                @AlexMurphy I also thought that it was impossible, I'll tell you the steps i went through.
                1. I downloaded the retropie img, and formatted my sd card.
                2. Then i used Win32 Disk Imager to write the img to my sd card.
                  3)After that, I took out my sd card, plugged everything up, switched it on, then raspbian booted, no sign of retropie whatsoever
                i downloaded retropie from this website.
                  AwesomeAzzy @celly
                  @celly No, it was an sd card already formatted, so there was no NOOBS anywhere.
                    A Former User
                    That's weird.
                    Are you sure that's the SD card you're using in the pi?
                      AwesomeAzzy @A Former User
                      @itsnitro stfu broπŸ˜‚πŸ˜‚ yes ofc i am
                      AlexMurphyA ? 3 Replies Last reply Reply Quote 0
                      • AlexMurphyA
                        @AwesomeAzzy Copy and paste the name of the .img file you are using. What is the unzipped size of the file?
                        • AlexMurphyA
                          @AwesomeAzzy This is the file you should be using and its' size.
                          A 2 Replies Last reply Reply Quote 0
                            @AlexMurphy ![alt text](image url)0_1490552425786_upload-e6a50c4d-ade4-49dc-923d-2605400c78d4 ahh, well, good thing I know where the proper one is, thanks a lot, i'll it and ill get back to you with the result.
                              A Former User @AwesomeAzzy
                              @AwesomeAzzy why are people so mean
                                AwesomeAzzy
                                @celly ikr smh rip dis dank world
                                  @AlexMurphy You are a bloody legend, yasssssssss it worked, thank youuu so much brutha
