    Is it possible to use 2 USB drives for storage? (RetroPie)
    usb driveemustationretropie
    3 Posts 2 Posters 866 Views
      Allanbuzzy
      I tried using 2 USBs however, the one I mainly use, the 32gb one, transfered some of the files to the 16GB one I had. I put in the retropie-mount folder, is it possible to make it so that it doesn't copy those files from that USB to the 16gb one?
      "What do you play games on?"
      "A LEGO brick."
      "LEGO What?
        Allanbuzzy
        Okay, I'm wondering if I can make a Raid and the Pi can detect the raid as one. Is it possible or not?
        "A LEGO brick."
        "LEGO What?
        anasazi29A 1 Reply Last reply Reply Quote 0
        • anasazi29A
          anasazi29 @Allanbuzzy
          @Allanbuzzy I'm not sure the Raspberry Pi will allow you to raid USB devices together.
          There are these little gadgets that might come in handy.
          http://www.ebay.com/itm/MMC-SD-HAT-for-the-Raspberry-Pi-/201697243538?hash=item2ef617b192:g:4BAAAOSwawpXwf8f
