    Help with Drastic
    drasticissuesmenuconfigs
    7 Posts 2 Posters 2.3k Views
    • W
      WhyCan'tIJustDie
      HI there, I am having trouble with Drastic, from what I have seen in videos and other posts (ex.
      ), people are able to enter the Drastic menu by pressing M, but whenever I do this I only get a black screen, I am able to exit this menu by normal means but I can not configure anything, help or pointing me in the right direction would be appreciated, Thank You.
        backstander @WhyCan'tIJustDie
        @WhyCan'tIJustDie
        I think this is a known issue with 4:3 monitors/TVs. I'm not sure about a work around. Maybe someone else on here knows of one.
        • W
          WhyCan'tIJustDie @backstander
          @backstander Thank you, yes I am using 4:3 T.V., do you think that hooking it up to a 16:9 T.V. or monitor would work?
          B 2 Replies Last reply Reply Quote 0
            @WhyCan'tIJustDie
            Yes
            • W
              WhyCan'tIJustDie
              Thanks, I am new to these forums, if I can can how would I mark this a solved, or is that the Admins job?
                @WhyCan'tIJustDie
                You might try this:
                https://retropie.org.uk/forum/post/51220
                  @WhyCan'tIJustDie
                  I think if you asked the questions with unresolved then you can mark as resolved. I'm actually not sure how it works lol
