    Picade vs. RetroArch: controller mapping problems and menu hotkey
    picaderetroarch.cfgretroarchcontrollerpi 2
    4 Posts 3 Posters 1.9k Views
      chorlton2080
      Grrrr! I've read the instructions for RetroArch time, and time, again. Apparently, setting a controller up in EmulationStation should also map RetroArch buttons.
      Despite this, the chosen SELECT and START buttons on my Picade have no effect in RetroArch. The mappings do, however, work flawlessly in MAME and other emulators.
      I'm sure I'm not using a "per-Core" config, so I would expect Default mappings to apply.
      Also, the keys to activate the menu in the Spectrum core are different to the lb-* cores in the arcade emulators - again despite the per-Core settings file being the default.
      Can anyone help?
      • AlexMurphyA
        AlexMurphy Banned @chorlton2080
        @chorlton2080
          chorlton2080 @AlexMurphy
          @AlexMurphy I did. But thanks, it would have been just as easy to answer my question.
          BuZzB 1 Reply Last reply Reply Quote -2
            BuZz administrators @chorlton2080
            @chorlton2080 You didn't as you provided none of the requested information in the post - but with your attitude, you are unlikely to find any help here (or last very long on this forum).
