    Setting 4-way D-Pad for menu and some games
    xbox wireless
    6 Posts 4 Posters 2.2k Views
      DEWx
      Hi there,
      the D-Pad of the XBox 360 Wireless Controller im using seems to issue a lot of "bad inputs". While navigating the menu i often get switched between platforms/emulators but just wanted to scroll up/down, or vice versa. Also in some games this makes problems.
      My guess is that the controllers d-pad issues "diagonal" inputs instead of the meant one, i.e. " left+down" instead of "down" only. Maybe its just to sensitive? But you cant calibrate the d-pad, right?
      In the end i need to know how i can configure the menu and some games to use the D-Pad as four-way-input instead of an 8-way input.
      I have tried the xboxdrv already with it's "four-way"-option (forgot the name) but the setting was ignored. But even if thats the solution (and i messed up something) i didnt found how i could set that four-way-option only for menu and some games. Some games require 8-way-input ...
      Regards,
      DEWx
      herb_fargusH mediamogulM 2 Replies Last reply Reply Quote 0
      • herb_fargusH
        herb_fargus administrators @DEWx
        @DEWx in Emulationstation you can at least disable system switching from the detailed list view
          mediamogul Global Moderator @DEWx
          @DEWx
          I have tried the xboxdrv already with it's "four-way"-option... but the setting was ignored... i didnt found how i could set that four-way-option only for menu and some games.
          When included into a xboxdrv launch command correctly, there's really no way it would be ignored. If you want to give it another try, there are a few ways to troubleshoot issues I can help you with. As for using it only in certain scenarios, if you could give some examples, I can tell how or if they'll be possible.
            DEWx
            Thanks for your answers! And sorry for my late reply ...
            @herb_fargus - Where can i disable that? And how i could get back to the "system"-menu? Probably I didnt get exactly what you mean :-/
            @mediamogul - Maybe the issue was, that the controller was set up before using the "default-driver" (not xboxdrv)?
            Few days ago I had problems when adding other controllers (PS3- and a Logitech-PC-controller) having weird behavior with unlogic order of the controllers. To keep it easy ... What would I need to do, to (re)install the xbox-controller using xboxdrv (while removing it first, incl. the other driver) and, if possible, make it "4-way" for SNES and the Menu.
            Thanks!
            DEWx
            AlexMurphyA mediamogulM 2 Replies Last reply Reply Quote 0
            • AlexMurphyA
              AlexMurphy Banned @DEWx
              @DEWx In the MAIN MENU on ES under UI SETTINGS change QUICK SYSTEM SELECT to OFF. To get back to the System menu just press the back button, usually B.
                @DEWx
                If you're talking about the Xpad driver, as long as you include --detach-kernel-driver in the xboxdrv launch command, the two drivers should be able to coexist without issue.
