Retropie installation problem under raspbian SDL
HI .
I can't launch retropie under raspbian Jessy distribution.
Installed retropie from the tuto.
Compiled the SDL 2.
But it"s not working. Got this message under the Term:
lvl0: Error creating SDL window!
Could not get EGL display
lvl0: Renderer failed to initialize!
lvl0: Window failed to initialize!I've tried to compiling sd2 with flags but still the same .
Help :)
@sunmetis Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first
You should probably use the premade image.
RetroPie also comes with own sdl2. You can't run it from the desktop btw. It won't work with the Jessie SDL2.
