    O2 Joggler running Retropie .
    o2 jogglerretropiexubuntu 14.04new install
    25 Posts 3 Posters 7.8k Views
    • hawseyH
      hawsey @hawsey
      Messing about with Retroarch now , i can by changing the emulator , get the sound from the game starting up also i got some graphics for a few seconds , then the music kind of jittered then stuck , at which point i sniggered , Mrs Hawsey then stuck her head in the room and said " are you ever going to grow up " .....
      I'll keep messing
      hawseyH 1 Reply Last reply Reply Quote 0
      • hawseyH
        hawsey @hawsey
        I got no further forward really other than it all installs including Retroarch now , all menus etc seem to work and Roms can be added which show up in their relevant console in the dash , also scraping seems to work .
        The games just won't boot , I'm trying NES only at present .
        Would there be any point in trying other systems at this juncture ?
        Is it likely to be the limitations of the hardware or the missing graphics stuff as previously mentioned ?
        I realise that Pi 3 is where it is at now so don't want anyone wasting any time on this unless it is feasible.
        That being said I'm sure a Joggler could be found for any DEVs wanting a bash at it :-)
        Thanks for the help people
          BuZz administrators @hawsey
          @hawsey retroarch is crashing on the joggler. I tried a few driver backend but it may require workarounds in retroarch. It's likely due to joggler gfx driver problems.
          • hawseyH
            hawsey @BuZz
            @BuZz thanks for delving a bit deeper , i appreciate it , would that likely be worth sorting ? And would it be a lot of work ?
            Looking on YouTube i found an old vid of Streefightet 2 working off MAME which looks great , also Quake3 on another so it looks like stuff should run ok obviously there would be limitations and i realise Retroarch is not MAME .
            • hawseyH
              hawsey
              Is this likely to be something someone in the Retroarch forums could help with BuZz or do you not think it would work anyway ?
