    Bomberman playable with 16 human (or CPU)
    gametestbombermandevelopmentcore
    29 Posts 5 Posters 11.4k Views
      sonicsheppard
      Hi @alexis-puska , just wanted to confirm that I have the latest version (running Update.sh tells me I am up-to-date), but I'm still missing all audio.
      Thanks.
        alexis-puska
        I have tried to compile on old version of retropie 3.8 -> OK
        transfert to a new pi with new version of retropie -> KO.
        The same compilation resultats don't work on the updated version of retropie and jessie, i continue to look inside and debug.
          sonicsheppard @alexis-puska
          @alexis-puska Thanks for the update.
          Hopefully you can get to the bottom of it :) Thanks!
            alexis-puska
            Hi all,
            @sonicsheppard
            I have fixe the bug of sound library this night, i have found some time to fix it. you can update, compile and play it on the last version of retropie.
            Alexis
            • horsedH
              horsed
              i tried to follow all instructions here but when i got to
              this stage
              ./Compile\ pi.sh
              it was failing as i was out of memory
              is there any precompiled version or a easier way to play this?
                son_link @horsed
                @horsed In the README.md on Compilation indicate that it is necessary to edit /etc/dphys-swapfile and change this
                CONF_SWAPSIZE=100
                to
                CONF_SWAPSIZE=200
                After reboot and continue the instructions
                horsedH 1 Reply Last reply Reply Quote 0
                • horsedH
                  horsed @son_link
                  @son_link
                  i changed swap file size and then made it unlimited but still no dice.
                    alexis-puska
                    @horsed said in Bomberman playable with 16 human (or CPU):
                    In fact if you change the swap size of raspberry, reboot and compile that work's.
                    here a link to download the compilation for RPi2/3
                    https://drive.google.com/open?id=1Y9goeDtf0z6A6_CKb6fC-4G8ca8W_zRm
                    • horsedH
                      horsed @alexis-puska
                      @alexis-puska thanks for the reply,
                      can you give me some instructions on how to instaall this, sorry i was following a guide before and not sure what i need to do.
                      also does your version have the saturn wide screen massive map?
