    PS4 controller, right analogue stick wont work at all
    ps4 controllersbluetooth
    25 Posts 5 Posters 13.1k Views
      darthlink
      Hi, so here is the thing, the ps4 controller work perfectly with any console emulator and also with the psx. The probleme is that every other emulation dont need to have 2 analogue stick to play the games, only the psx. I also need to mention that in the retropi controller configuration, i swith the setting from the D-Pad to the left analogue stick because i rather move through the menu with the analogue stick then the d-pad. My problem is that i can ONLY get 1 analogue stick to work and it does not matter if it is the left or right analogue, only one work at the time. With games that need only 1 stick to work, it is ok but unfortunatelly, i cant play quake2 or soul reaver with only 1 analogue stick, i need both.
      Even if i let the normal controller configuration ( d-pad on d-pad and analogue stick properly ) the in retroarch a select d-pad to analogue and select either the left or right stick, it work but only for 1 stick, i still cant get bot analogue stick to work.
      What can i do to have both analogue stick to work on psx emulator games please ?
      B mediamogulM 2 Replies Last reply Reply Quote 0
        backstander @darthlink
        @darthlink
        I assume you're playing the PSX versions of Quake 2 and Soul Reaver? ;-)
        When this is set for the PSX RetroArch emulator (lr-pcsx-rearmed), it makes the games think you don't have any analogue sticks and the left analogue stick is just the same as the D-Pad which is fine for the older PSX games that didn't use the analogue sticks but will cause the issues you're having for games that look for the analogue sticks.
        You'll need to set the controller type to analog:
        https://retropie.org.uk/docs/Playstation-1/#analog-controller-type
        Also to enable analog sticks (disable use analog stick as d-pad) for PSX you can edit /opt/retropie/configs/psx/retroarch.cfg with these values:
        input_player1_analog_dpad_mode = "0"
        input_player2_analog_dpad_mode = "0"
        input_player3_analog_dpad_mode = "0"
        input_player4_analog_dpad_mode = "0"
        You might have to experiment with these settings.
        D 2 Replies Last reply Reply Quote 0
        • DarkWolfD
          DarkWolf
          This post is deleted!
            mediamogul Global Moderator @darthlink
            @darthlink
            Moved to 'Help and Support'.
              darthlink @backstander
              @backstander said in PS4 controller, right analogue stick wont work at all:
              Thank you for the reply, i will try that as soon as possible. I would like to know what are the "0" for please ? and why for 4 player ?
              DarkWolfD 1 Reply Last reply Reply Quote 0
              • DarkWolfD
                DarkWolf @darthlink
                @darthlink
                You can set the dpad mode to 4 different states:
                0 = unset
                1 = disabled
                2 = left stick
                3 = right stick
                You can also set these in the Configuration editor in the retropie menu
                benefits: gui and no keyboard needed
                  darthlink @DarkWolf
                  @DarkWolf said in PS4 controller, right analogue stick wont work at all:
                  @darthlink
                  0 = unset
                  1 = disabled
                  2 = left stick
                  3 = right stick
                  Thanks for the number information. As for the retropie GUI, that is where i had set it up and also where i had switch between dpad to analog by choosing analogue up instead of dpad up for example. That work fine but i could still not have the right analog stick working.
                  The input player1 to player4, is it for 4 controller config ? In any case, i will revert the controller config to normal as dpad to dpad and analog to analog and change the controller type in here: https://retropie.org.uk/docs/Playstation-1/#analog-controller-type i hope it will work.
                  I also saw that there is a driver for the ps3 controller in the retropie_setup_script.sh, could that work for the ps4 controller as it is pretty much the same thing ?
                  • DarkWolfD
                    DarkWolf @darthlink
                    @darthlink
                    Actually there is a driver for ps4 controllers called ds4drv
                    sudo apt-get update && sudo apt-get install python3 && sudo apt-get install python-dev && sudo apt-get install python3-dev && sudo apt-get install python-pip && sudo pip install ds4drv && wget https://raw.githubusercontent.com/chrippa/ds4drv/master/udev/50-ds4drv.rules && sudo mv 50-ds4drv.rules /etc/udev/rules.d/ && sudo udevadm control --reload-rules && sudo udevadm trigger && ds4drv --led 000008
                    This downloads the ds4drv and the required packages to install it... If it finishes without errors it is waiting for connections, so set your controller into pairing mode and see if it connects... If it does press ctrl+c to exit this
                    Than execute:
                    sudo nano /etc/rc.local
                    and add this line before the exit 0:
                    /usr/local/bin/ds4drv --led 0000ff &
                    than press ctrl+x, than y and enter
                    reboot your pi afterwards... Now it will look for ps4 controllers while es loads up...
                    EDIT: NOTE YOu have to set the controller into pairing mode on startup
                    EDIT2: You can change the ps4 led color by editing the rgb color code after --led
                    You could give this a try
                    D 2 Replies Last reply Reply Quote 1
                      darthlink @DarkWolf
                      @DarkWolf
                      Thank you very much, i will try this this evening as i am at work right now and connected to my PI through ssh loll ( dont tell my boss ) loll so i will let you know later if it did work or not.
                      Thanks again ;)
                        darthlink @DarkWolf
                        @DarkWolf
                        I had just did everything you said and i did not get any error installing the driver and it did pair in a pink flash color loll. But somehow it got worst, quake2 does not even start anymore now!! It is not the emulator because i can lauch Final Fantasy 8 with no problem. I still cant test if the left analog stick works because i cant start quake2 anymore right now. What can i do please ?
                          darthlink
                          Now it got even worst, my controller does not stay pair, it pair for 5 seconds then it unpair automatically :(
                          I have to go to bluetooth in retropie to select: pair all registered devices and that used to always work but now it does it for a few seconds then the controller shutdown or get unpaired !!! What is going on ?????
                          • DarkWolfD
                            DarkWolf @darthlink
                            @darthlink That's realy wierd I have to say, that never happens to me though.. I had no problems after installation...
                            It should have been blue (if you didn't change it)
                            you can still uninstal it with
                            sudo pip uninstall ds4drv
                            and remove the added line in /etc/rc.local
                              darthlink @DarkWolf
                              thats weird because it really did flash pink ish for a second when it paired loll And the controller could pair back to my ps4 so its broken or anything. I will try again later this evening but some how i thought it had worked but then like i said it could not keep the pairing.
                              Could it be because after all i did was to change the code color to 003300 wich should be dark green but do you think that may have caused the problem ? I will put it back to 0000ff this evening and see if somehow it stay paired.
                              • DarkWolfD
                                DarkWolf @darthlink
                                @darthlink if you did it correctly the color change isn't a problem here.
                                  @backstander
                                  I did change the controller type to analog but still not working unfortunately.
                                    darthlink
                                    The ds4drv is now uninstalled because it ( somehow ) meesed up the bluettoth communication in the case that i would not stay connected to bluetooth. Without the ds4drv, the bluetooth between the PI3 and my controller works perfectly.
                                    The controller still with with every games with every emulators also. The probleme that remains is the fact that only the left analog stick works fine. Either by switching the D-pad to analog or in retroarch to switch d-pad to analog then it work but i only get one stick working at the time.
                                    If in retroarch i select the right stick in ( d-pad to analog ) then the right stick work fine but not the left stick.
                                    How can i have both analog stick to work at the same time please ?
                                      darthlink
                                      I still would need help please for that issue, does anyone use a ps4 controller over bluetooth and without a bluetooth dongle ? Does it work and if yes, how please ?
                                        Sheldon25 @darthlink
                                        @darthlink As far as the controller not staying connected, did you remember to execute this command?
                                        /usr/local/bin/ds4drv --led 0000ff & exit
                                        A few notes from my observation in using ds4drv. I use both ps3 and ps4 controllers on my pi using the built in bluetooth on the latest firmware. I followed this guide (https://github.com/retropie/retropie-setup/wiki/PS4-Controller)
                                        Since this script starts upon boot, it auto assigns/reserves the slot for ps4 controller as player 1. It could create issues if you want to use one controller over another. I notice that the ps4 controller has a slight lag to it. When installing the service and testing the connection I notice that ds4drv shows low signal and ranges from 10-30 reports a second.
                                          darthlink @Sheldon25
                                          @Sheldon25 said in PS4 controller, right analogue stick wont work at all:
                                          Thank you very much, i will try that.
                                          As for the right analog stick, does yours work ok ?
                                          • DarkWolfD
                                            DarkWolf @darthlink
                                            @darthlink All my ps4 controllers are working out of the box (with the latest kernel!), connection is stable (ds4drv is very unstable) and the inputs are correct (no ghost inputs, ds4drv has ghost inputs)...
                                            So, I expirienced that ds4drv is a really bad implementation of drivers for ps4 cotrollers.
                                            D S 2 Replies Last reply Reply Quote 0
