    Help for a novice please!
    installing
    9 Posts 3 Posters 2.7k Views
      kottal
      I bought a raspberry pi 3 with noobs installed on a 32gb microsd. I downloaded retropie onto my laptop and then used Etcher to transfer the retropie image to the sd. I no longer appear to have raspbian. Is there a way of having both? Help please!
      DarkWolfD 1 Reply Last reply Reply Quote 0
      • DarkWolfD
        DarkWolf @kottal
        @kottal
        Yes, of course!
        Here are instructions on how to use NOOBS:
        http://www.makeuseof.com/tag/how-noobs-for-raspberry-pi-can-help-first-time-users/
        System: Raspberry 3 Model B, RetroPie 4.2.1
        Storage: 16gb Micro SD, 64gb USB Drive
        Theme: Updated NBBA
        Documentation solves many problems: https://retropie.org.uk/docs/
          kottal @DarkWolf
          @DarkWolf so I now need to reformat sd and reinstall noobs?
          DarkWolfD D 2 Replies Last reply Reply Quote 0
          • DarkWolfD
            DarkWolf @kottal
            @kottal
            If you want to use noobs, yes
            If you want to install Retropie on a existing Raspbian system thatn just run the RetroPie-Setup Script on that.. You can than start it on the Raspbian User Interface
            In addition:
            There is already a topic about this here:
            https://retropie.org.uk/forum/topic/5746/dooble-boot-raspbian-retropie
            Theme: Updated NBBA
              dudleydes @kottal
              @kottal RetroPie is built upon Raspbian lite OS so Raspbian is already installed. I presume you mean the PIXEL desktop environment. Instructions to install PIXEL can be found here.
                kottal @dudleydes
                @dudleydes yes I was hoping to access Retropie from the desktop menus. When I boot up now it goes straight to retropie. What's the easiest way of getting the menu back and accessing from there ? Reinstall noobs and run a retropie setup script or do the pixel thing you said?
                • DarkWolfD
                  DarkWolf @DarkWolf
                  @DarkWolf Like I said, there is already a topic and a wiki page about that, follow this instructions and you will have what you want:
                  https://github.com/RetroPie/RetroPie-Setup/wiki/Manual-Installation
                  Theme: Updated NBBA
                    dudleydes @kottal
                    @kottal RetroPie and EmulationStation cannot be run from the desktop but you can launch the PIXEL desktop from ES. If you prefer, you can boot into the desktop instead of ES - instructions to do this are here. In this case, you would need to exit the desktop to launch ES.
                    How you wish to proceed is up to you - either install PIXEL in RetroPie and have the desktop as a launch option in ES or install RetroPie on NOOBS, which has the desktop already installed, using the links provided by @DarkWolf.
                      kottal
                      Thanks all much appreciated
