    Sometimes no sound through HDMI
    no soundsnesgba
    11 Posts 5 Posters 5.5k Views
    • W
      weiserlinker
      Hi,
      I got a new raspberry pi 3 B and installed the latest retropie build. When I play games, sometimes the sound disappears and comes back a few seconds later. This happens mostly with snes and gameboy games. I tried using different emulators and settings, but it didn't help.
      With for example psx games there are no sound dropouts.
        mediamogul Global Moderator @weiserlinker
        @weiserlinker
        It's likely a post-processing feature of your television. Take a look through the menus for anything that might normalize audio volume and turn it off.
        • W
          weiserlinker
          I turned all the tv features off now, tested different hdmi cables and the problem still is there
            @weiserlinker
            Just to rule it out completely, do you have another television you can test on to see if the problem is happening there as well?
            • W
              weiserlinker
              Yes. Tested it on two other tvs, but still the same.
                @weiserlinker
                Very strange indeed. I can't think of anything related to RetroArch/RetroPie that would cause audio to fade in and out like that. Do you run your audio through any kind of receiver or other component at all?
                • W
                  weiserlinker
                  Only through an hdmi extension cable. But I connected the pi directly without the extension and the problem still occurs.
                  • CapemanC
                    Capeman
                    Turn this setting on in config.txt just in case it's the tv processing the DVI+sound signal wrong, this will force the hdmi output to act like a normal dvd/blueray player and not a PC signal.
                    hdmi_drive=2
                    Make sure your HDMI cables are not cheapo chinese junk, i had an hdmi cable extension that i used on my pi zero that caused crackled image and audio noise, upgraded to an expensive one and all problems went away.
                    • W
                      weiserlinker
                      As I said, I used only the HDMI cable and the sound still disappears sometimes. I use th Wii U HDMI cable, so it;s not a cheap one.
                      And the setting hdmi_drive is already set to 2.
                        backstander @weiserlinker
                        @weiserlinker
                        I just got a new TV (Hitachi Roku TV) and I've been having audio dropping issues but I hadn't had a lot of time to really test and troubleshoot the issue but I've noticed after extended play in Kodi, that my audio starts dropping but I'll hear part of a sound every couple seconds or so (happens both in and outside of Kodi). I'm not sure if our issues are related.
                        Another thing you might try along with adding "hdmi_drive=2" is to also add this to /boot/config.txt:
                        # Pretends all audio formats are supported by display, allowing passthrough of DTS/AC even when not reported as supported.
                        hdmi_force_edid_audio=1
                        https://retropie.org.uk/docs/Sound-Issues/#users-configurations
                          pjft
                          Have you tried setting audio_sync to on in RetroArch? I'm not sure it solves the same thing you're experiencing, but I had audio distortion when frame rates skipped and this helped a bit. It was a long time ago so I might be misremembering things though.
