    Odd issue with xin-mo question
    configurationbutton mapping
    3 Posts 3 Posters 615 Views
      andymck
      Installed retropie and connected everything up. Xin mo works perfectly apart from in everything apart from Mame.
      eg. Streetfighter on SNES emu both players perfect with 6 buttons.
      Streetfighter on MAME player 1 perfect with all 6 buttons recognised but player 2 only sees 4 buttons.
      (I think it is the shoulder buttons on the SNES emu)
      Same with Mortal Kombat.
      This only happens in Mame
      Any Ideas?
      Thanks in advance
      Andy
        paul.lab
        I am having exactly he same problem pi2 & xin mo
        did you ever get it sorted? if so do you have any hints
          Magnum77
          Not sure if this helps. I had problem where the 2:nd player use the P1 controls.
          . Needed to add:
          usbhid.quirks=0x16c0:0x05e1:0x040
          To the /boot/cmdline.txt to get the player 2 control to be detected. Not sure if this is related at all.
          https://github.com/RetroPie/RetroPie-Setup/wiki/Xin-Mo-Controller
