    Cabinet build - almost finished
    cabinetcontrollerbuttons
    47 Posts 12 Posters 21.0k Views
      meleu @spruce_m00se
      @spruce_m00se nice build man! Can we start that cheevos related tweaking? :-)
      spruce_m00seS 1 Reply Last reply Reply Quote 0
      • spruce_m00seS
        spruce_m00se @meleu
        @meleu I dont have time anymore unfortuantely, I had 5 weeks, I took 4 to build this, I have one left to do a paid project that has nothing to do with gaming :(
        if someone can manage to make a gpio pin toggle from high to low when a high score or cheevo is achieved then I would probably pay them to do it right now.
          meleu @spruce_m00se
          @spruce_m00se said in Cabinet build - almost finished:
          Do you know what is the command to toggle from high to low from command line?
          If yes, just put the command on that script I wrote for you here: https://retropie.org.uk/forum/post/95321
          You just need to launch RetroArch with verbose logging to make it work. I don't have the fancy lights and don't know how to deal with GPIO stuff, but I tested with simple output on a terminal and the script works as expected.
          No need to pay! :)
          • spruce_m00seS
            spruce_m00se @meleu
            @meleu it seems pretty straight forward on this link :
            http://www.raspberry-projects.com/pi/command-line/io-pins-command-line/io-pin-control-from-the-command-line
            • spruce_m00seS
              spruce_m00se @Capeman
              @capeman said in Cabinet build - almost finished:
              I want to say:
              /opt/retropie/configs/all/retroarch-joypads
              But im at work and sadly cant mess around on my pi right now - i'll post a copy of my config files for you to reference later tonight.
              If you have the same button layout as mine above, you could technically use them outright with maybe a little modification.
              any luck getting the files up?
              • CapemanC
                Capeman
                Oh wow, haha i completely forgot. Kids and work, ya know. I'll see if i have copies on my laptop and post them on my lunch break (if i have them)
                • spruce_m00seS
                  @capeman I completely understand, dont worry about it for now, im out on holiday for the next three weeks, then my kids are back, so its game over, if you have a chance then I will do it at some point, but as of now it doesnt look like i will touch it again for the next month.
