EmulationStation Resolution setup help.
Hi All
I'm building a retrostyle ps2 kiosk but I have run into a problem:
I use a wide screen tv as monitor but the hole in the PS2 kiosk i 4:3. So my issue is that i can't seem to configure EmulationStation to be 4:3... or in anyway configure the resolution.
Retropie and Emulators are running fine in 4:3 but not EmulationStation.
Has anyone got a solution to this problem? (and no, i can not just find a 4:3 tv :)Kind Regards
Toke -
@founthouse launch emulationstation with your resolution:
emulationstation --resolution 640 480
This post is deleted! -
Hi @herb_fargus
Thanks for the reply
Tried that and it worked, but it was left orientated and i couldn't find any way to change the viewport. And it reset on restart.
Kind Regards
Toke
