    Attractmode with USB
    attr
    17 Posts 3 Posters 3.7k Views
      stevep
      How do I redirect attractmode to my USB drive. This is where all.my roms are stored. It's currently directed at the SD card.../home/pi/Retropie/roms/mame-libretro
      • InsecureSpikeI
        InsecureSpike
        I've done it this way, take it from me its the easiest and most reliable way
        https://retropie.org.uk/docs/Running-ROMs-from-a-USB-drive/
        RPi 3 - RetroPie + 500gb HDD [consoles] + Razer Onza Tournament
        RPi 3 - RetroPie + 32gb USB [computers] + Keyboard
        both with AttractMode + FuzzBoxx Layout
          stevep
          I've already done that and it works fine when using ES but when using AM it needs to be redirected. AM currently is looking at the SD card......./home/pi/retropie/roms/emulator. I need to know the correct path to input in the AM config file which will redirect it to the external USB drive.
          • InsecureSpikeI
            InsecureSpike
            have you tried a full update via RetroPie Setup?
            does anything attractmode update any of your configs?
            when i set mine up it linked itself i did not need to edit any paths, except my custom ones
            but, in my config files the paths are
            /home/pi/RetroPie/roms/(name-of-folder)
            which is what you have already
            remember to back up your sd card before updating, just in case
            • InsecureSpikeI
              InsecureSpike
              i just looked at the path you posted, is that exactly how you have it in the confg files?
              as retropie should be RetroPie
                stevep
                The path is /media/usb0/retropie-mount/roms/emulator
                • InsecureSpikeI
                  InsecureSpike
                  you have it all working ok now?
                    stevep
                    ES works fine but AM is spotty. My guess is that the runcommand needs to be tweaked but that's beyond me.
                    • InsecureSpikeI
                      InsecureSpike
                      it's very odd, that my ES and my AM use the exactly the same paths, but yours don't?
                      did you use the Auto Mount (easiest method)
                      or Manual Mount Method?
                        stevep
                        In ES I just enabled USB support and it looks to the USB drive. In AM you have to configure it manually in the emulator setup screen.
                        • InsecureSpikeI
                          InsecureSpike
                          as i now believe using the easy method, links and generates the matching paths, so the same paths are used in both instances
                          so you shouldn't have to link it like you have. i will try it again later to confirm, as that's how mine is set up and i've done no editing of any configure files, and my rom list were automatically generated when i did an update via RetroPie Setup
                            stevep
                            I think I know what's happening here. I'm building off a downloaded image of attract mode. That's why it's not matching up with my USB.
                              stevep
                              I used the auto mount with the image found on the Retropie site. The attractmode image came from another source.
                              • L
                                lomoverde
                                im pretty new to this and am keen to know if im wrong,but isnt the easiest method writing the image to usb,then just having the boot sector copied to a tiny sd ?edit a line in the cmdline to point to the usb.
                                InsecureSpikeI 1 Reply Last reply Reply Quote 0
                                • InsecureSpikeI
                                  InsecureSpike @lomoverde
                                  @lomoverde said in Attractmode with USB:
                                  personally i think these methods are safer, just in case something goes wrong with an update or something then all you'll have to do is replace the ad card and your away, and you know your roms are safe, i used to do the moving file system method, but i had corruption happen 2-3 times and then replacing yer roms can be a pain (if you have a few).
                                  this way when you get your set up the way you want back up your card, and your good to go
                                  • L
                                    lomoverde
                                    ok,cant say ive encountered usb corruption so far.any problems ive had are microsd related.
                                    i can understand what a pain replacing rom collections would be tho,hope im not blindly walking the line haha.
                                    • InsecureSpikeI
                                      InsecureSpike
                                      not usb corruption,
                                      file system corruption, a minor issue could happen with an update, once i had drop in connection, and all was fucked
