    Trying to send roms over to RetroPie 0 with PuTTY
    retropieputtygamingroms install
    3 Posts 3 Posters 2.6k Views
      Chaosaholic
      I started up retro pie project this morning and I'm almost done. All I have to do is send over the roms using PuTTY, but I have no idea what commands I'm supposed to use, and I haven't been able to find a tutorial or even a hint at what I'm supposed to do. I've been searching all morning please help, and thanks in advance.
      • BAZLOCOB
        BAZLOCO
        you need to use winscp - its a free FTP program
        https://github.com/retropie/retropie-setup/wiki/Transferring-Roms
        or you can use the samba share if you have your pi connected to your home network.
        in windows explorer type \RETROPIE into the address bar and you have access to the roms folder
          mrdally204
          I have been sending roms over my network using the network share (SMB) that is built into RPi. If you are on windows, go to windows explorer and click on Network. In there you should see all your networked machines that are sharing. RETROPIE should be one of them. once you are there, navigate to the roms folder and you can drag and drop to your hearts content. :)
