    vice says press play on tape and nothing happens
    vicetapec64press play on
    34 Posts 5 Posters 15.2k Views
    • maxbeanzM
      maxbeanz @edmaul69
      @edmaul69 TDE vastly improves compatibility. Buzz probably knows more about what works and what doesn't work on lr-vice. Also about Warp mode, the emulator auto enables it / turns it off when booting games, but with 6581 Fast SID set it's actually loading slower!
        edmaul69 @maxbeanz
        @maxbeanz i actually dont mind not using warp. The fact that i have to wait for the game to load kinda gives me a sense of realism. I use original controllers for my systems too so i get the authentic feel of using a real machine.
          edmaul69 @maxbeanz
          @maxbeanz you say warp is set by default on loading? Since the retroarch gui lets you change the sid, i tested each one from a fresh selecting of a disk game and from the time the blue screen pops up to the time it changes to flipping color screen, both fast sid's were 5 seconds faster than the others, so im not sure what the the slow loading issue is?
            AliBengali @maxbeanz
            Good morning @maxbeanz - yes - i don't understand it too. Everything is fine - i am running amiberry/whdload too- its running great. But my vice dont like tapes (these are zip's from
            Gamebase64 v15). But i'll try to install binary again. I changed some options in vice. I read it before - changing much settings is no good idea with vice like you mentioned, @mediamogul
            Anyway- yesterday i bought a logitech wireless keyboard with touchpad. This was planned long time before ... So its more comfortable to use retropie/c64 or lr-vice or just play some old sierra games like Space Quest 1&2. But ill try the hint from you @edmaul69 - to controll the gui via controller.
            Have fun, all together!
              A Former User @edmaul69
              @edmaul69 said in vice says press play on tape and nothing happens:
              I remember some games on Atari & C64 took up to 30 minutes to load from tape. Spectrum was better - 5 minutes (without turbo gadgets), but still. I'm all up for realism but this is where I draw the line :)
              edmaul69E 1 Reply Last reply Reply Quote 3
                edmaul69 @A Former User
                @arkive well that is a bit excessive. So on lr-vice with the fast sid's it takes 1:20 to load a disk. That isnt too bad. Need to test tape time
                maxbeanzM 1 Reply Last reply Reply Quote 0
                  edmaul69
                  About the same for tapes
                    AliBengali @edmaul69
                    @alibengali if you go into the retroarch gui and go into quick menu options and change controller0 type from keyboard to joystick it then allows you to enter vice menu and vice keyboard from a controller. also one of the controller buttons makes your analog the mouse so you can control everything with your controller now.
                    Its working! Thank you. I never touched anything in Retroarch - i was always scared about these lot of options... and scared to destroy my whole good running retropie 4.2 Setup). I bet i should read some more about how it all works together (Emulationstation, Retroarch, Emulators) to understand that. Perhaps then i will find the Problem why "my vice" dont like Tape Images. Perhaps there's something to edit (eg the Script responsible for starting vice with parameters). But perhaps the configuration of vice itself..... and not retroarch....
                    Update:
                    In Vice i see the t64 File in the temporary dir (the t64-file is original stored in zip)- so the automatic unzipping process is running fine.
                    In the zip-file there is the image t64 and the version.nfo.
                    But the d64 files are working great. The d64 are stored in zip, too (d64 and version.nfo).
                    Will have a look this evening (still not at home)..... like i wrote: try to install vice binaries again.
                      A Former User
                      The worst offenders on C64 were the tape versions of disk games, but also some tape-only curiosities. Here are some bad un's: http://www.lemon64.com/forum/viewtopic.php?t=38423
                      I didn't have a disk drive back in the day, yet of course still wanted to play big games like Pirates! or Defender Of The Crown. Used to do my homework while waiting...
                        AliBengali @A Former User
                        @arkive said in vice says press play on tape and nothing happens:
                        • maxbeanzM
                          maxbeanz @edmaul69
                          @edmaul69 Just out of interest, did you do a comparison with normal vice to check the speed differences ? It doesn't take anywhere near 1:20 to load a disk. As I said before, vice/lr-vice automatically sets Warp mode ON when booting but because lr-vice is set to 6581 Fast it loads even slower than normal. If you turn on the Status Bar in the lr-vice options (F10) you can see. (Maybe the SID modes aren't implemented correctly).
                          For example :-
                          'Mayhem in Monsterland' in 'lr-vice' takes 2 minutes !! to get to the cracktro screen.
                          In regular 'vice' it takes 27 Seconds.
                            A Former User
                            A basic question: how do I actually map Vice functions to a joypad? (wired Dualshock 3). At the moment "emu menu" is mapped to L3, I'd like to change it.
                            And not so basic question: anybody used it with a CRT? On mine - with Pi2SCART- it doesn't look too good, it's kinda fuzzy. Pixels definitely not 1:1. (I switched off the CRT filters in the options)
                            Also, when I set "max resolution limit" in vid options to Fixed, pixels become 1:1, but the display is scaled improperly (black bars at top and bottom, left & right goes bit off screen). I tired adjusting other vid options but to no avail,
                              you just go to the menu function in menu and press "m" on keyboard.
                              Now you have to press a key to bind this key to the function.
                                AliBengali @AliBengali
                                ****** SOLVED: *******
                                In Vice i used "reset settings to defaults" and now Tape-Images are loading!
                                But i am afraid to say the "save settings" option is not really reliable/stable (i can "save" changes of my settings - but at the next start the changes are gone... Have to check that now....
