Rpi3 Sixad won't start, can't find bluetooth adapter. Please help.
Did you try downgrading Bluetooth from 1.1 to 1.0?
In case you didn't here is what you need to type in the terminal:
wget http://archive.raspberrypi.org/debian/pool/main/p/pi-bluetooth/pi-bluetooth_0.1.0_armhf.deb
sudo dpkg -i pi-bluetooth_0.1.0_armhf.deb
sudo reboot -
No but I'll try it. I get an error though.
dpkg: error processing archive pi-bluetooth_0.1.0_armhf.deb (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
pi-bluetooth_0.1.0_armhf.deb -
The upgrade updates the on-board Bluetooth to 1.1 and that breaks in RetroPie.
It worked for me using SSH... Maybe try it in SSH?
@RetroPieNerd
That's what I'm in, SSH on my machine. Not working for me.
Here is the post I got the info from. See if this helps...
https://retropie.org.uk/forum/topic/905/lost-ps3-bluetooth-after-updating-raspbian -
Well no wonder it can't be found, you forgot the
part, mang.
Thanks though, ran it, rebooted, testing now.
Works perfectly.
Bluetooth starts on boot again. As soon as it rebooted I plugged in the PS3 controller and unplugged it, instant sync.
You are welcome. I had the same problem too.
No need to downgrade anymore....
You just need to install raspberrypi-sys-mods
sudo apt-get install raspberrypi-sys-mods
