    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 96.8k Views
    • hansolo77H
      hansolo77
      You guys are awesome. I haven't tried 1.5b (adding proper exit out of the loop) on my own system yet, but it sounds like you got it working. I hate not being home today to participate more. :) Thanks everybody! When I get a chance, I will put it into place and report back my own findings.
      Who's Scruffy Looking?
        meleu @cyperghost
        @cyperghost
        bug report
        Our method to kill the command placed on the 4th line of /dev/shm/runcommand.info fails to kill ScummVM emulator. This is why:
        [prompt]$ sed -n 4p /dev/shm/runcommand.info
        bash /home/meleu/RetroPie/roms/scummvm/+Start\ ScummVM.sh "ft"
        Then our approach kills bash processes.
        I'm currently trying to find a strong solution. Will post it soon...
          @hansolo77 @lostless @cyperghost
          Can you guys test this one? Let's call it v1.7:
          #!/bin/bash -x
          # Before using this script you need to install inotify-tools:
          #    sudo apt-get install inotify-tools
          # I'm just trying to help with the script logic here.
          # I DON'T HAVE A MAUSBERRY AND DIDN'T TEST THE GPIO STUFF HERE!
          #  U S E   I T   A T   Y O U R   O W N   R I S K ! ! !  #
          # meleu - July/2017
          # kudos for @cyperghost , who is very persistent in help you guys! :-)
          #this is the GPIO pin connected to the lead on switch labeled OUT
          GPIOpin1=23
          #this is the GPIO pin connected to the lead on switch labeled IN
          GPIOpin2=24
          echo "$GPIOpin1" > /sys/class/gpio/export
          echo "in" > /sys/class/gpio/gpio$GPIOpin1/direction
          echo "$GPIOpin2" > /sys/class/gpio/export
          echo "out" > /sys/class/gpio/gpio$GPIOpin2/direction
          echo "1" > /sys/class/gpio/gpio$GPIOpin2/value
          file="/sys/class/gpio/gpio$GPIOpin1/value"
          # up to here this code is executed at booting (/etc/rc.local)
          # let's wait for the creation of the "/sys/class/gpio/gpio$GPIOpin1/value"
          sleep 30 # not sure if 30 seconds is a good value...
          while inotifywait -qq -e modify "$file" ; do
              power="$(cat "$file")"
              [[ "$power" == 0 ]] && continue
              # explaining the crazy command below:
              # 1. get 4th line of runcommand.info (aka "emulator command")
              # 2. delete backslash '\' character
              # 3. replace every character that has a special meaning in a regex context with a dot '.'
              emu_command="$(sed -n 4p /dev/shm/runcommand.info | tr -d '\\"' | tr '^$[]*.()|+?{}' '.')"
              [[ -n "$emu_command" ]] && pkill -f "$emu_command" && sleep 10
              espid=$(pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)")
              if [[ "$espid" ]]; then
                  touch /tmp/es-shutdown && chown pi:pi /tmp/es-shutdown
                  kill "$espid"
                  exit
              fi
              sudo poweroff
          done
          I did a trick for debugging, then if this script doesn't work, please perform this command:
          grep 'rc\.local' /var/log/syslog > debug.log
          It creates a file named debug.log paste its conten in ghostbin.com or something similar.
          • lostlessL
            lostless @meleu
            @meleu still did not work. I did the grep thing and can't find the syslog directory to find debug.log. also i don't have the /sys/class/gpio/gpio$GPIOpin1 directory. not sure if thats useful, but trying to help.
              meleu @lostless
              @lostless please, paste here the output of these commands:
              ls -l /var/log/syslog
              and
              ls -lah /sys/class/gpio/*
              • lostlessL
                lostless @meleu
                first
                -rw-r----- 1 root adm 2281836 Jul 29 03:38 /var/log/syslog
                second
                -rwxrwx--- 1 root gpio 4.0K Jul 29 02:50 /sys/class/gpio/export
                lrwxrwxrwx 1 root gpio    0 Jul 29 02:50 /sys/class/gpio/gpio23 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio23
                lrwxrwxrwx 1 root gpio    0 Jul 29 02:50 /sys/class/gpio/gpio24 -> ../../devices/platform/soc/3f200000.gpio/gpiochip0/gpio/gpio24
                lrwxrwxrwx 1 root gpio    0 Jul 29 02:50 /sys/class/gpio/gpiochip0 -> ../../devices/platform/soc/3f200000.gpio/gpio/gpiochip0
                lrwxrwxrwx 1 root gpio    0 Jul 29 02:50 /sys/class/gpio/gpiochip100 -> ../../devices/gpiochip2/gpio/gpiochip100
                lrwxrwxrwx 1 root gpio    0 Jul 29 02:50 /sys/class/gpio/gpiochip128 -> ../../devices/gpiochip1/gpio/gpiochip128
                -rwxrwx--- 1 root gpio 4.0K Jul 29 02:50 /sys/class/gpio/unexport
                  meleu @lostless
                  @lostless
                  now these:
                  cd
                  grep rc.local /var/log/syslog* > debug.log
                  ls -l debug.log
                  • lostlessL
                    lostless
                    -rw-r--r-- 1 pi pi 16656 Jul 29 03:44 debug.log
                    i found a debug.log in the home (~) directory
                      meleu @lostless
                      @lostless open this file on your Windows (I'm assuming you're using Windows), select all text and paste on ghostbin.com
                      • lostlessL
                        lostless @meleu
                        @meleu nope mac. I can boot into windows if need be.
                          meleu @lostless
                          @lostless nop, I just need you to copy the entire file
                          • lostlessL
                            lostless @meleu
                            @meleu
                            its just
                            /var/log/syslog:Jul 23 06:28:29 genepi systemd[1]: Starting /etc/rc.local Compatibility...
                            /var/log/syslog:Jul 23 06:28:29 genepi systemd[1]: Started /etc/rc.local Compatibility.
                            over and over with different dates and times. nothing else.
                              meleu @lostless
                              @lostless now I need you to do the same thing for /etc/rc.local and /etc/switch.sh (the last one is supposed to be my v1.7 script, but please, paste it on ghostbin so I can really check if everything is fine)
                              • lostlessL
                                lostless
                                /etc/rc.local
                                https://ghostbin.com/paste/goucc
                                /switch.sh
                                https://ghostbin.com/paste/5agap
                                  meleu @lostless
                                  @lostless
                                  ls -l /etc/switch.sh
                                  • lostlessL
                                    lostless
                                    @meleu said in Mausberry Shutdown Script Doesn't Save Metadata:
                                    -rwxrwxrwx 1 root root 1889 Jul 29 02:42 /etc/switch.sh
                                      meleu @lostless
                                      @lostless
                                      damn! I'm not getting what's wrong! Let's try this:
                                      sudo bash -x /etc/switch.sh & 2> /home/pi/script-debug.txt
                                      And then press the f%#&ing button. Pretty please... :)
                                      It should turn off your pi...
                                      • lostlessL
                                        lostless
                                        @meleu aaaaaaaaaaaaaannnnnnnddddd...................
                                        ...........NO GOOD. >:( sorry man.
                                        • lostlessL
                                          lostless @meleu
                                          @meleu
                                           + GPIOpin1=23
                                          + GPIOpin2=24
                                          + echo 23
                                          /etc/switch.sh: line 22: echo: write error: Device or resource busy
                                          + echo in
                                          + echo 24
                                          /etc/switch.sh: line 24: echo: write error: Device or resource busy
                                          + echo out
                                          + echo 1
                                          + file=/sys/class/gpio/gpio23/value
                                          + sleep 30
                                          + inotifywait -qq -e modify /sys/class/gpio/gpio23/value
                                          the readout of that and its stuck. My terminal has not finished what its doing.
                                            meleu @lostless
                                            @lostless are you able to use IRC? maybe it's better than this forum for an online conversation... :P
                                            edit I'm at #retropie at irc.freenode.net
                                            lostlessL 1 Reply Last reply Reply Quote 1
