    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 108.1k Views
      cyperghost
      Yes I kill only retroarch ... but I'm not sure if this is enough. If your script can find out all running emulators then the usecase works for all. But I haven't tested out now if killing emulator ... waiting 2 seconds ... hoping that ES writes XML file ... does work.
      I think that's @hansolo77 job and then it would nice not to always kill the emulator process (=shotgun method) rather if it running, so you need a new if-then branch or make use of case selection. But I believe that is not our job :)
      But you know I really appreciate your help, always!
        meleu @cyperghost
        @cyperghost said in Mausberry Shutdown Script Doesn't Save Metadata:
        AFAIK EmulationStation isn't able to launch more than one emulator. You must exit the emulator, then go back to ES and then launch another emulator. Then killing the command that stays in the 4th line of /dev/shm/runcommand.info looks like a good approach for me.
          cyperghost
          That will work. Indeed ....
          in runcommand.info is everything stored but not if an emulator is currently running or not.
          I would rather use runcommand.log runcommand.info, too
          4th line
          /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fceumm/fceumm_libretro.so --confi....
          and check pgrep /opt/retropie/emulators/retroarch/bin/retroarch for ex. if PID > 0
          if yes, then an emulator seems to be running if PID empty or 0 then there is no emulator.
          So it is surly possible to detect every emulator-run proper initiated by runcommand.sh
          Thank you
          @hansolo77 got his toolbox now ;) He should use it :)
            meleu @cyperghost
            @cyperghost Wow! You really confused me! PID > 0? Also, why are you so obsessed in killing retroarch? Is it your next victim after you killed EmulationStation so many times like it was Kenny (Sourth Park)? :)
            If you pkill an inexistent process it doesn't hurt anything, then IMHO there's no need to check if that command is still running.
            [PROMPT]$ pkill -f blablabla
            [PROMPT]$ # see? nothing happens! :)
              cyperghost
              PID > 0 means it is running or not ;)
              Okay than the approach is easy if pkill does not hurt :)
              pkill -f "$(sed -n 4p /dev/shm/runcommand.info)"
              @hansolo77? There is a new toy ;)
              Please instead of pkill retroarch use line above. Can you please test?
              If all proper runs it can be pushed to version 1.3
              ES is not a victim, it behaves like a sqarehead but with a few tricks it can be calmed down ;)
              Knowledge is power and thank you @meleu to share your knowledge with us.
              I think thats our passion not obsession, that would be bad!
              • hansolo77H
                hansolo77
                Wow guys. My email inbox is spammed. :) I'm actually not too worried about getting it to save if I'm in the middle of a game. That situation rarely comes up, and to my memory only recently while troubleshooting all this. :)
                I will test v1.3 (adding the retroarch pkill) here in a little while. I'm suffering a massive migraine. Have had it the last 3 days. Every now and then it act's like it's feeling a little better and I can get some work done with this. I'm honestly thrilled that I've got you guys pulling your hair out on all this and have a working solution already. :)
                Who's Scruffy Looking?
                meleuM cyperghostC lostlessL 3 Replies Last reply Reply Quote 1
                  meleu @hansolo77
                  @hansolo77 said in Mausberry Shutdown Script Doesn't Save Metadata:
                  Which hair? :-)
                    cyperghost @hansolo77
                    @hansolo77 Please test like you want pkill retroarch works just for libretro-cores, the sniplet of @meleu works with all things that were started through runcommand.sh - so it's the more versatile way
                    Which hair :-)
                    nose hair! What an awful torture!
                    • lostlessL
                      lostless @hansolo77
                      The 1.2 script is working great for me as well.
                      @hansolo77 I've solved the saving issue by having retroarch to check and write to disk the srm files every 10 seconds if its new. Its an option in retroarch under the saving menu. I learned a hard lesson powering off in the middle of a game and losing about an hours worth of gameplay.
                        meleu @lostless
                        @lostless said in Mausberry Shutdown Script Doesn't Save Metadata:
                        Can you share with us what is the exact option for this? I'm highly interested.
                        I had a similar issue while playing Terranigma after freeing 4 continents. I was playing on my GPD XD (Android device) and left the device in standby but the battery was over. And then the srm file wasn't saved... :( You know, RPGs are very time consuming...
                        @cyperghost that's why you don't see me talking about Terranigma recently. But I'll try it again!
                          cyperghost @meleu
                          I'm also highly interested
                          Do that! I'm just stick in the middle of the game. You need so much time for RPG but it makes real fun.
                            meleu @cyperghost
                            @cyperghost I think I've found it!
                            The option is autosave_interval. Look here: https://github.com/libretro/RetroArch/blob/master/retroarch.cfg#L785
                            300 should be a good value. 300 seconds = 5 minutes
                            EDIT: via menu it's Settings -> Saving -> SaveRAM Autosave Interval.
                            lostlessL 1 Reply Last reply Reply Quote 1
                            • lostlessL
                              lostless @meleu
                              @meleu that's it. I did some testing a while ago and it only writes a new file if it's been changed. So 10 seconds works good for me.
                              • hansolo77H
                                hansolo77
                                Good stuff! So just to clarify, that's saving the nonvolatile RAM right? Not creating a Save State? Because of RetroAchievments, I typically just leave my RetroArch in Hardcore mode, which disables Saves States and Cheats.
                                Sorry about last night and my headache. I wasn't fully following the discussion between @cyperghost and @meleu. When I get a chance, I will try it with the command:
                                • lostlessL
                                  lostless @hansolo77
                                  @hansolo77 yes just the sram. Not savestates. By default the sram stays in RAM until you exit. This just checks the sram every x seconds and sees if there is a change. If so, it writes to disk.
                                  • hansolo77H
                                    hansolo77
                                    That added line to the script seems to break the script. I added the 1.3 changes (using the original pkill retroarch > /dev/null 2>&1 bit), then I changed it to the pkill -f "$(sed -n 4p /dev/shm/runcommand.info)". For some reason now, whenever I press the power button nothing happens. At first I thought it was because the pkill command was nested inside the if statement. When I SSH'd into the system and checked top, ES was no longer running when RetroArch was. So the new additions to the script weren't getting picked up. I moved it (as a test) outside if functions. Still nothing happened. I've experimented with doing sudo reboot from the SSH terminal as well as via ES shutdown (from the menu). In both cases, the power button still doesn't work. I can, however, power the system on from a complete power plug pull via the button, so I know the switch is still good. You sure that's the right command?
                                    • hansolo77H
                                      hansolo77
                                      OK, further "looking around"... the original script (v1.2) wasn't working either. So I went back to the unedited v0.0 (the one Mausberry has you install). That one didn't work either! So I checked out the install script, and saw they're adding a line to rc.local. I'm not sure what that file is, but when I edited it, it had 2 instances of the script path /etc/switch.sh in there. I took one out and rebooted. Now the original script is working right. Gonna try putting in the new changes and see if that was my problem.
                                      EDIT Still a no-go on that 1.3 edit. :(
                                      EDIT 2 Facepalm - I think it might be a file properties issue now... I rechecked the Mausberry install script and noticed they're doing a chmod +777 on the script prior to rebooting. Since I already had a working script, I moved it to a backup file before making changes. I saved the changes to a new file and renamed it to be what it should be. But I suspect the +777 isn't there. So I added that bit in the terminal and just rebooted. The system now shuts down correctly (using the 1.2 script). Now testing 1.3.
                                      EDIT 3 Ha! That was the trick. But it's not saving the metadata. It might be that it's not giving it enough time to return to ES before cutting the power... When I hit the button, it turns off the emulator, and I see the RunCommand box (haven't set up the launching images yet). At the bottom of the screen there is a line that says "Terminated", then the system turns off..
                                      EDIT 4 I don't think this script in it's current form works well. I tried adding a second to the sleep timer. Then tried to test the script just as is before actually launching a game. The script launches, but the system never shuts down. ES closes, but that's it. I don't know if it's getting hung up on the sleep or what. But the only way I can recover is by pulling the plug. With the 2 added (v1.3) lines # commented out, the system fully powers down again. I think there needs to be additional lines of code to include an if/then/else. IF emulator is running, THEN kill and wait, ELSE shutdown ES. But will that even execute if an emulator isn't running? Would it need to read out as "IF emulator, THEN kill emulator and wait, THEN kill ES.. ELSE kill ES"?
                                      PS - I'm done for the night. :)
                                        cyperghost
                                        So I think it we should provide and maintain v1.2 only!
                                        Get the version for Mausberry circuits shutdowns from here
                                        Thank @hansolo77 for testing this
                                        This script will properly shutdown ES and saves it's metadata if you press power button on your mausberry circuit!
                                        • Metadata is needed to save scraped games, favorites and last played record upon next reboot
                                        • This script will work if your are in EmulationsStation
                                        • This script will not properly save metadata if you shutdown during gameplay or if your RPi is locked (So return to ES by pressing start+select on your gampad and then shutdown!)
                                        # End Emulationstation if condition of running binary is true
                                        # v1.0 07/21/17 by cyperghost - Inital run
                                        # v1.1 07/22/17 - Added chown command to set right user permission for creating es-shutdown
                                        # v1.2 07/23/17 - Some small improvments, easier to maintain, removed echo, removed else branch
                                        # greetings @pjft for his famous favorits and @meleu for the RegEx sniplet
                                        espid=$( pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)" ) # detect PID of ES binary only
                                        if [ "$espid" ]; then                                                         # Condition: PID is not equal 0 or empty then use ES shutdown
                                           touch /tmp/es-shutdown && chown pi:pi /tmp/es-shutdown                     #v1.1 Change file permission of es-shutdown to user:group pi:pi
                                           kill $espid        #v1.2 use kill@detected PID - easier to maintain now!
                                           exit
                                        fi
                                          cyperghost @cyperghost
                                          EXPERIMENTAL!!!
                                          Converted from @meleu to kill all emulators
                                          It worked (saved recently used games) for me in SSH but I've no chance to test >> lack of mausberry!
                                          # End Emulationstation if condition of running binary is true (Shotgun-version - no support!)
                                          # v1.4 07/25/17 - Shotgun method to terminate all launchs by runcommand (not maintained, use v1.2 for support)
                                          #### Experimental part ####
                                          IFS=" "
                                          set – $( sed -n 4p /dev/shm/runcommand.info ) > /dev/null 2>&1
                                          pkill $2 && sleep 4                                                           # v1.4 Sleeptimer to give ES chance to save XML filestate (untestested)
                                             touch /tmp/es-shutdown && chown pi:pi /tmp/es-shutdown                     # v1.1 Change file permission of es-shutdown to user:group pi:pi
                                             kill $espid        # v1.2 use kill@detected PID - easier to maintain now!
                                          exit
                                          fi
                                            meleu @cyperghost
                                            @cyperghost some notes
                                            • the indentation can be improved :)
                                            • the default IFS is space, tab and newline. I think there's no need to set it as space
                                            • I'm not getting the reason why you are messing with the set command (unnecessary complexity)...
                                            the suggested command doesn't work for you?
