    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 107.9k Views
      cyperghost @meleu
      @meleu yes
      pkill -f "$(sed -n 4p /dev/shm/runcommand.info)" Does not work. So you need to extract just binary call... I tested with retroarch, glide64 and zdoom. All were prober working by set-command
        meleu @cyperghost
        @cyperghost said in Mausberry Shutdown Script Doesn't Save Metadata:
        @meleu yes
        weird. I'm not able to test on my actual RetroPie, but look the test I've made:
        [PROMPT]$ sleep 1000 &
        [1] 8648
        [PROMPT]$ cat test.info
        1st line
        2nd line
        3rd line
        sleep 1000
        bla
        bla
        bla
        [PROMPT]$ pkill -f "$(sed -n 4p test.info)"
        [1]+  Terminated              sleep 1000
        But I noticed an issue when the file to look for the 4th line doesn't exist... then my suggestion is to use this
        [[ -f /dev/shm/runcommand.info ]] && pkill -f "$(sed -n 4p /dev/shm/runcommand.info)"
        Can you test it on a real RetroPie setup?
          cyperghost @meleu
          @meleu Not now ... Have to work :)
          Cya mate!
            meleu @cyperghost
            @cyperghost I found the problem: that line from runcommand.info has some double quotes wich is confusing the pkill. Here's my current solution:
            rcinfo=/dev/shm/runcommand.info
            [[ -f "$rcinfo" ]] && pkill -f -9 "$(sed -n 4p "$rcinfo" | cut -d' ' -f1)"
            I tested on my retropie here and it seems to work. Please test it when you have a chance.
            Cheers!
            • hansolo77H
              hansolo77
              You guys are just talking gibberish again. For somebody who's unfamiliar with all of this, I'm completely lost. RetroPie is only my 2nd ever Pi project, and really only my first exposure to the scripting side of it. I'm eager to learn, but throwing out seemingly random lines of code without reference or instruction on where to place it doesn't help me any. :) No biggie, I'll get there. I'm just totally unfamiliar with the commands. set sed, IFS.. totally new to me. I only just learned about top like 4 days ago. ^_^
              So tomorrow after work, would you rather I test @cyperghost's v1.4 or replace that section with @meleu's? Or would it be better to just wait and let ya'll hash it out some more?
              Who's Scruffy Looking?
                meleu @hansolo77
                @hansolo77 haha... sorry for the nerdy stuff. :)
                my suggestion is to try this:
                espid=$(pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)")
                if [ "$espid" ]; then
                    [[ -f "/dev/shm/runcommand.info" ]] \
                    && pkill -f -9 "$(sed -n 4p "/dev/shm/runcommand.info" | cut -d' ' -f1)" \
                    && sleep 4
                    touch /tmp/es-shutdown && chown pi:pi /tmp/es-shutdown
                    kill $espid
                fi
                • hansolo77H
                  hansolo77
                  Ok cool. I'm going to bed soon so I will test this tomorrow when I get off work. If not right away, I'm off Thursday, so plenty of time then.
                    cyperghost @meleu
                    @meleu
                    You can even improve :)
                    Edit runcommand-onend.sh and add
                    sudo rm /dev/shm/runcommand.info
                    or make PR to runcommand.sh :)
                    Because runcommand.info isn't removed if emulator ends by start+select button :) It isn't really needed but it's a nice cleanup and definates the addition to the GPIO script you made with more sense.
                      meleu @cyperghost
                      @cyperghost it can be useful for debugging. I prefer to keep it even after the emulator has finished.
                        cyperghost @meleu
                        @meleu And why do you check presence of runcommand.info in your script? Don't get me wrong but I think the filecheck only makes sense if you remove that after emulator call ends? Because you will always run the "sleep 4"-command even if you are only in ES :)
                          meleu @cyperghost
                          @cyperghost because if the file doesn't exist that sed will fail and print nothing (empty string).
                          Just for fun do the following
                          1. save all important file you have open.
                          2. perform this command: pkill -f ""
                          3. cry (well, if you saved the files you don't have to cry. as I didn't saved, I cried)
                          Explaining: using an empty string as the pattern matches "everything". And the result is pkilling every single process owned by the pkiller!
                          I noticed it on an unpleasant way. :)
                            cyperghost
                            @meleu Okay ... what about this one?
                            It's pretty save and finds out PID of every emulator :)
                            #!/bin/bash
                            emucall=$(sed -n 4p /dev/shm/runcommand.info)
                            emupid=${emucall#* }
                            pos=$(expr ${#emucall} - ${#emupid})
                            emupid=$(pgrep -f ${emucall:0:$pos})
                            kill $emupid
                            Then if PID is a true value kill first the emulator and then kill ES in seconds instance... Thank your for every suggestions - I learn really a lot of your examples!
                              meleu @cyperghost
                              #!/bin/bash
                              kill $emupid
                              Wow! It's a bit complex, isn't it?
                              Yeah, using parameter substitution is a good solution here. But I would simplify it with this:
                              emucall="$(sed -n 4p /dev/shm/runcommand.info)"
                              [[ -n "$emucall" ]] && pkill -f "${emucall% *}"
                              By the way, sometimes I feel like we are messing @hansolo77 's thread with all those bash snippets. I'm going t open a bash thread for us. :-)
                              EDIT: topic created https://retropie.org.uk/forum/topic/11900/shell-scripting-topic
                              • lostlessL
                                lostless @meleu
                                @meleu i think it's all relevant. I'm a mauseberry user as well and I find it interesting that I can make it finally function the way it needs to in a retropie setup. If we can get it to quit an emulator, save the sram And then save the meta data for emulation station, the better. I'm elated that my switch now saves meta data when in emulation station. I've had to redo scrapping so many times. 👍
                                • hansolo77H
                                  hansolo77
                                  Here here! Thanks @lostless :) I knew I wasn't alone in this. And yeah, you guys are just leaving me in the dust with all these snippets. I'd love to learn how to do all that on my own too, but until I do I have to rely on you guys coming up with solutions for me to test and try.
                                  I hate to say, I have a migraine again tonight, so I'm not gonna be much help in troubleshooting a new method/addition. But I will try to do it tomorrow since I'm off work.
                                  • NamErehWonN
                                    NamErehWon
                                    Correct me if I'm wrong, but it appears that the script monitoring the GPIO isn't debouncing the input. You would have to hold the button for up to a second depending on where in the sleep you hit it. This should cover debouncing and make it so you could require a hold of a specific length of time.
                                     #GPIO init stuff here
                                     previous_power = 0
                                     while [ 1 = 1 ]; do
                                        power=$(cat /sys/class/gpio/gpio$GPIOpin1/value)
                                        if [$power != $previous_power]; then
                                           sleep 0.05 #might need to be tweaked. You can make it 1s+ to require a hold
                                           if[$power != 0];then
                                              #shutdown code here
                                           fi
                                        fi
                                        previous_power = $power
                                        #you can put a short sleep here if need be
                                     done
                                    meleuM cyperghostC 2 Replies Last reply Reply Quote 0
                                      meleu @NamErehWon
                                      @namerehwon I don't know the details about this GPIO thing, but I don't think that an infinite loop like that would be a good approach.
                                      Maybe you can improve your script above using inotify-tools like in that script you saw on another thread.
                                        cyperghost @NamErehWon
                                        @namerehwon Well that's out of our focus. We want to
                                        1. Reboot ES proberly
                                        2. Save metadata in all situation
                                          2.1 In ES mode (solved with version 1.2)
                                          2.2 If any emulator is running (@meleu and @cyperghost coproduction)
                                        But it's a good thing to debounce GPIO keypress but is that needed?
                                        It isn't necessary imho because one keypress will effect an action >> Reboot.
                                        There isn't a toggeling or keypress needed. So it doesn't matter if the signal is produces 1 times or 100 times :) - my personal opinion
                                        • caver01C
                                          caver01 @cyperghost
                                          @cyperghost but isn't @NamErehWon saying that in the current config, because of the loop timing it may not pickup the button press unless you hold it long enough for a cycle to see it? I have noticed this with my mausberry before I shifted to a python script using edge detection.
                                          Better detection of the button press seems like a good improvement on the script to me even if it expands the scope of the thread a little.
                                            cyperghost
                                            ah okay - thx
