    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 107.9k Views
      meleu @cyperghost
      @cyperghost said in Mausberry Shutdown Script Doesn't Save Metadata:
      @meleu Do you think you can break the endless 1 second loop?
      yes.
      I googled about how this device works and I think I found a solution. This is my last atempt...
      Some notes about what I found:
      • this script is called at boot (/etc/rc.local)
      • After changing the script the user needs to reboot to check if it will work.
      Some notes about the script below, v1.6 (OK, let's put a version to avoid confusion):
      • I think that at the time of calling the file we are monitoring doesn't exist (that's why I'm putting a sleep before monitoring the file.
      • I'm not getting why the f&$%k that exit after killing ES is needed. It makes the script stop at the exit, and then the sudo poweroff won't be executed. The strange thing is that the exit is present on v1.2 and @lostless says that it's working...
      • before this script needs the inotify-tools installed.
      #!/bin/bash
      # Before using this script you need to install inotify-tools:
      #    sudo apt-get install inotify-tools
      # I'm just trying to help with the script logic here.
      # I DON'T HAVE A MAUSEBERRY AND DIDN'T TEST THE GPIO STUFF HERE!
      #  U S E   I T   A T   Y O U R   O W N   R I S K ! ! !  #
      # meleu - July/2017
      # kudos for @cyperghost , who is very persistent in help you guys! :-)
      #this is the GPIO pin connected to the lead on switch labeled OUT
      GPIOpin1=23
      #this is the GPIO pin connected to the lead on switch labeled IN
      GPIOpin2=24
      echo "$GPIOpin1" > /sys/class/gpio/export
      echo "in" > /sys/class/gpio/gpio$GPIOpin1/direction
      echo "$GPIOpin2" > /sys/class/gpio/export
      echo "out" > /sys/class/gpio/gpio$GPIOpin2/direction
      echo "1" > /sys/class/gpio/gpio$GPIOpin2/value
      file="/sys/class/gpio/gpio$GPIOpin1/value"
      # up to here this code is executed at booting (/etc/rc.local)
      # let's wait for the creation of the "/sys/class/gpio/gpio$GPIOpin1/value"
      sleep 30 # not sure if 30 seconds is a good value...
      while inotifywait -qq -e modify "$file" ; do
          power="$(cat "$file")"
          [[ "$power" == 0 ]] && continue
          emu_command="$(sed -n 4p /dev/shm/runcommand.info)"
          [[ -n "$emu_command" ]] && pkill -f "${emu_command%% *}" && sleep 12 # the value of 12 was suggested by @lostless
          espid=$(pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)")
          if [[ "$espid" ]]; then
              touch /tmp/es-shutdown && chown pi:pi /tmp/es-shutdown
              kill "$espid"
              # I'm not getting why the heck this exit is necessary, it makes
              # the "sudo poweroff" not be executed if the logic reaches this point
              exit
          fi
          sudo poweroff
      done
        cyperghost @meleu
        @meleu That's easy....
        The exit is needed becasue it ends the mausberry GPIO script and gives control to emulationstation.sh for proper exit
        Can you please exchange your lines
        with this one?
        emupid="$(sed -n 4p /dev/shm/runcommand.info)"                                #v1.5 @meleu readout 4th line command.info
        emupid="$(pgrep -f "${emupid%% *}")"                                          #v1.5 optain PID emucall by runcommand.sh
        if [ "$emupid" ]; then                                                        #v1.5 check correct PID > avoid sleeptimer if shutdown from ES
            kill $emupid && sleep 10
        fi
        It is really the better way. Because you check value of command.info ... this value will also be active if you are back in ES so your [[ -n "$emu_command" ]] is always true and the sleep timer will used in every situation. Even if an emulator is not active. So this would be the last version called 1.6 release :)
        Haha ... we will see my friend :)
          meleu @cyperghost
          You're right. Good catch!
          The nerdy stuff we can discuss on our other thread ;-)
            cyperghost @meleu
            @meleu @hansolo77 @lostless
            This is also my last posting on this theme!
            We have three working versions now!
            meleus version 1.6 which got all features of v1.5 but gots faster GPIO response (breaks 1 second loop, use inotify tool - it's not finished now so WIP)
            cyperghosts + meleus version 1.56 which will end ES and all emulators called by runcommand.sh
            cyperghosts version 1.2 which just ends ES
            meleuM 2 Replies Last reply Reply Quote 0
              meleu @cyperghost
              @cyperghost the credit for v1.6 is not meleu's only! :)
              By the way, are you sure it really works?
              cyperghostC lostlessL 2 Replies Last reply Reply Quote 0
                cyperghost @meleu
                @meleu Yes it should work. I tested it via SSH only but I also took investigation into the python ESC-script. There is a sleep timer of 10 seconds... so 10 seconds should be a good value :)
                 for pid in pids:
                        try:
                            commandpath = open(os.path.join('/proc', pid, 'cmdline'), 'rb').read()
                            if commandpath[0:24] == '/opt/retropie/emulators/':
                                os.system('kill -QUIT %s' % pid)
                                print('kill -QUIT %s' % pid)
                        except IOError:
                            continue
                It uses kill PIDcommand to end emulators in path with path /opt/retropie/emulators/
                Your RegEx sniplets matches better :) So it works - to 100% I guarantee (tested with N64Glide and zdoom) ... there the python script would fail :)
                for v1.6 the GPIO tuning part is 100% yours. So you created it! The others part are nearly same as 1.5 so it should also work.
                Finetunig is not included like setting sleeptimers and notify - Do you agree?
                You also invested much time and you improved my commands and coding style as I explaind you the need of f%&/! exit command or introduced the second % in pkill -f "${emu_command%% *}" for example. But it is nothing against the && explaination and your RegEx magic, the magic of the testing command, the sed-command, the investigation of the runcommand.info-file ....
                So thank you :)
                • lostlessL
                  lostless @meleu
                  @meleu 1.6 does not work. It acts as if the switch is not working. The inotify i don't think is being triggered.
                  cyperghostC meleuM 2 Replies Last reply Reply Quote 0
                    cyperghost @lostless
                    @lostless How about 1.5? Did you check if the script is loaded? Are the permissions are right setted?
                    • lostlessL
                      lostless @cyperghost
                      @cyperghost 1.5 works. which script are we talking about? the one we've been working on? I'm assuming so because it works when not trying to use inotify.
                        meleu @lostless
                        @lostless said in Mausberry Shutdown Script Doesn't Save Metadata:
                        WTF?!!!!
                        It's now a matter of honor!
                        Let me just put the kids to sleep (4-6 hours) and I'll get this achievement make it work!
                        (By the way, my first try will be to use the full path to inotifywait. If you know how to do it, please try it in advance.)
                          cyperghost
                          @lostless Okay good news!
                          I'm a bit unaware of the inotify thing but I see no error in the script.
                          So I think you've three choices
                          1. Use 1.5 it will work with PowerOff in ES and emulator screen and will properly save metadata (easiest approch, because it's ready setted)
                          2. Investigate to 1.6... I see no errors in the script, it may be a file permission error or inotify works wrong
                          3. Create new script and touch control ...
                            3.1 I was able to get in touch with gpio-watch and it worked really fine with some scripts I made and it debounces switches relativly good. All in all it's also a lightweight
                            3.2 Use wiringPi (overloaded) and use it's posibilty for IRQ
                            3.3 There are tons of other GPIO libaries ...
                          Surly!
                          @meleu I already said, you're not finished with that :)
                          But I'm glad that you made detection via file change ... So I hope you'll get it to run.
                          I just checked v1.6 there seems to be no typing mistake or mistake in GPIO numbering!
                          For maintainig ... If you are finished with 1.6
                          Can you please transform 1.5 in same way (coding style and layout) as 1.6? But withouth the inotify-thing?
                          So we have 2 versions
                          1. Version 1.5 that just works without installing anything
                          2. Version 1.6 with improved GPIO handling, but needs a new package
                          • lostlessL
                            @cyperghost @meleu Thanks to you both. The 1.5 is fine for me. I know @meleu, you are definitely obsessed with making the switch work without the mauseberry loop. But i've been using my pi for almost a year with that loop and it working just fine. At least we've reached a point were the mauseberry runs perfect for a retropie setup. I won't lose meta data anymore.
                            cyperghostC 1 Reply Last reply Reply Quote 2
                              @lostless Is the sleeptimer of 9 seconds not to long?
                              I took the value out of the python script (they used 10 seconds) but I assume it was written for an Pi 1. So I think 5-6 seconds should also work.
                              No .. it's not obsession it's passion!
                              But I'm also interested in the inotify thing
                              • lostlessL
                                @cyperghost I can experiment, 9 seems good enough. i can try lower, but as long as it shuts down, it doesn't matter much.
                                  @lostless The 9 seconds are only triggered if an emulator is running! And it's important for saving metadata after the emu is closed.
                                  • lostlessL
                                    Is there a difference. Its all a matter of perspective LOL
                                    • lostlessL
                                      Ya, its fine as i usually don't shut down from a game, so in that respect, having to wait will hardly be noticed.
                                        cyperghost
                                        @lostless If you are obsessed by a woman or passionated by a women makes a big difference.
                                        If you don't know then ask a judge and a producer of love toys what the difference is :)
                                        • lostlessL
                                          @cyperghost getting all philosophical on me? Lets not derail to far, but i think i clearly under stand the difference between obsession and passion. Obsession is passion gone too far, when there is no need to keep going. When all is lost, yet you continue. When the path has reached its end and you gone over the cliff. I think I'm done.................. :/
                                            cyperghost
                                            @lostless You're right. You may help us in outfinding the best sleeptimer :) That's your passion :) you can also use floating number like 2.5 to pause
