    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 116.3k Views
    • lostlessL
      lostless @meleu
      @meleu i see you removed some stuff from the original script
      while [ 1 = 1 ]; do
      power=$(cat /sys/class/gpio/gpio$GPIOpin1/value)
      if [ $power = 0 ]; then
      sleep 1
      else
      that was removed. any reason to that?
        meleu @lostless
        @lostless said in Mausberry Shutdown Script Doesn't Save Metadata:
        yep. This infinite loop is consuming CPU cycles unnecessarily.
        • lostlessL
          lostless @meleu
          @meleu that was in the original script from mauseberry. never had any issues. interesting that their code just constantly checks the gpio.
            meleu @lostless
            @lostless do they have a github repo or something?
            • lostlessL
              lostless @meleu
              @meleu they don't. just the download and install instructions on their website. But heres the script you download and install.
              echo '#!/bin/bash
              #this is the GPIO pin connected to the lead on switch labeled OUT
              GPIOpin1=23
              #this is the GPIO pin connected to the lead on switch labeled IN
              GPIOpin2=24
              echo "$GPIOpin1" > /sys/class/gpio/export
              echo "in" > /sys/class/gpio/gpio$GPIOpin1/direction
              echo "$GPIOpin2" > /sys/class/gpio/export
              echo "out" > /sys/class/gpio/gpio$GPIOpin2/direction
              echo "1" > /sys/class/gpio/gpio$GPIOpin2/value
              while [ 1 = 1 ]; do
              sleep 1
              else
              sudo poweroff
              fi
              done
                meleu @lostless
                @meleu killed all switch functionality. As in it no longer functions as a shutdown switch.
                is it killing the emulator/ES?
                • lostlessL
                  lostless @meleu
                  @meleu its not doing anything.
                    meleu @lostless
                    @lostless did you install inotify-tools?
                    • lostlessL
                      lostless @meleu
                      @meleu yes
                      meleuM 2 Replies Last reply Reply Quote 0
                        meleu @lostless
                        @lostless OK, let's try with that expensive infinite loop just to check if the inotifywait part is bugging the script. Hold on a little...
                        • lostlessL
                          lostless @meleu
                          @meleu I'm trying my own Frankenste in script (taking the parts that i see may work)
                            meleu @lostless
                            @lostless please, try this one:
                            #!/bin/bash
                            GPIOpin1=23
                            GPIOpin2=24
                            file="/sys/class/gpio/gpio$GPIOpin1/value"
                            while true; do
                                power="$(cat "$file")"
                                if [[ "$power" == 0 ]];
                                    sleep 1
                                else
                                    emu_command="$(sed -n 4p /dev/shm/runcommand.info)"
                                    [[ -n "$emu_command" ]] && pkill -f "${emu_command%% *}" && sleep 5
                                    espid=$(pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)")
                                    if [[ "$espid" ]]; then
                                        touch /tmp/es-shutdown && chown pi:pi /tmp/es-shutdown
                                        kill "$espid"
                                    fi
                                    sudo poweroff
                                fi
                            done
                            • lostlessL
                              lostless @meleu
                              @meleu your new script is still doing nothing and mine worked just like the 1.2.
                                meleu @lostless
                                @lostless helping with this blind coding is very hard. I'm giving up...
                                • lostlessL
                                  lostless @meleu
                                  @meleu sounds good man. it was fun. the 1.2 works fine, a lot better then always losing meta data all the time.
                                    meleu @lostless
                                    @lostless where is this script placed? what directory?
                                    lostlessL 2 Replies Last reply Reply Quote 0
                                    • lostlessL
                                      lostless @meleu
                                      @meleu location is /etc/switch.sh
                                      • lostlessL
                                        lostless @meleu
                                        @meleu My frankenstein script is working. Thank you so much for giving me insight. I know i didnt contribute anything to the code, but I feel like a kid in the 80/90s, discovering computers before they were made easy to use.
                                        i found you need to give time for retroarch to quit and emulation station to reload before you try quit emulation station. i gave it 12 seconds. 5 was not enough, by the time the emulator quit, emulation station was not fully loaded back in.
                                        here is what i came up with
                                        #!/bin/bash
                                        GPIOpin1=23
                                        GPIOpin2=24
                                        while [ 1 = 1 ]; do
                                        sleep 1
                                        else
                                        # End Emulationstation if condition of running binary is true
                                        # v1.0 07/21/17 by cyperghost - Inital run
                                        # v1.1 07/22/17 - Added chown command to set right user permission for creating es-shutdown
                                        # v1.2 07/23/17 - Some small improvments, easier to maintain, removed echo, removed else branch
                                        # v1.works 7/27/17 (are we even trying to number this)  @lostless figured it out. More time to quit emulator and reload emulation station before shutdown. @cyperghost  thank you for initial run. @meleu thank you for your insight
                                                [[ -n "$emu_command" ]] && pkill -f "${emu_command%% *}" && sleep 12
                                        espid=$( pgrep -f "/opt/retropie/supplementary/.*/emulationstation([^.]|$)" ) # detect PID of ES binary only
                                        if [ "$espid" ]; then
                                           kill $espid
                                           exit
                                        fi
                                        sudo poweroff
                                        fi
                                        done
                                        @cyperghost Thank you for the first script up to 1.2.
                                        @hansolo77 give this a try. its working for me quite well.
                                          meleu @lostless
                                          @lostless can you try this one:
                                          #!/bin/bash
                                          GPIOpin1=23
                                          GPIOpin2=24
                                          while [ 1 = 1 ]; do
                                                  sleep 1
                                              else
                                                      kill $espid
                                                      exit
                                                  fi
                                                  sudo poweroff
                                              fi
                                          done
                                          It's exactly the same script as your Frankenstein, but with a nice indentation. If it works I will try one step further...
                                          I really would like to avoid that loop every single second!
                                            cyperghost @hansolo77
                                            @hansolo77 said in Mausberry Shutdown Script Doesn't Save Metadata:
                                            Testing v1.5 from here now....
                                            Take away - Looks like the script is properly closing out of the game I'm playing and returning to ES for a shutdown, but it's not saving the metadata when it shuts that down. I wonder if it's getting hung up in the if functions, not finding a valid true and going to the bottom of the script to the original poweroff without exiting ES first...
                                            You are 100% right.... made a small mistake - I forget to add exit command to break loop! Thank you
                                            So quick question... anybody know how to make a profile in Putty so it can automatically log in (username/password) so I don't have to keep typing it every time I try one of these tests? :)
                                            @lostless - version 1.5 should work now!
                                            Sorry... I forget to exit the loop thanks to @hansolo77 he helped me to detect the bug.
                                            Please mates try again with v1.5 of exit script (with working exit command now)
                                            I give you 100% working guarantee on this ;) You maybe have to extend timer.
                                            I would prefer this to @meleu solution because the sleep timer isn't used if there is no emulator running and the PID is detected and stored as $espid and $emupid This script can be extended to play and/or control backgroundmusic for ex. because it extracts PID
                                            @meleu Do you think you can break the endless 1 second loop?
