    Spontaneous left/right movements in everything
    random movementgamepad
    29 Posts 8 Posters 11.2k Views
    • N
      nazo
      So I recently reinstalled RetroPie after shuffling things around since I had a BerryBoot setup before but had problems after doing an update where it was rendered unusable for unknown reasons and I decided it would be best just to go straight to the source. For the most part everything works just great, however, I'm running into one extremely irritating problem: the system keeps getting spontaneous movements. As in I'm sitting there doing nothing and suddenly it acts like I had just pushed left or right. I guess about 80% left movements, 20% right roughly, which makes it more interesting in that it's not even consistent. (And never up or down either.) I don't know if it thinks the gamepad is actually showing that input or if it's something else, but I'm seeing this even in Kodi (which seems to implement its own controls rather than using the joystick to keyboard mapping that RetroPie seems to use I guess.) I haven't noticed it actually doing it in any games yet (maybe because the movement is so momentary) but it does do it in the RetroArch menus. In Kodi it is a critical problem because if I'm actually using Kodi for music/videos/whatever that mean it randomly jumps backwards (or sometimes forwards) without warning. Interestingly enough, I think the frequency of this is actually increasing over time. Originally it did it very very rarely. But now it's starting to do it more and more frequently and quickly requiring far less time. I might add that it didn't do it at all at first, so before anyone blames the third party HiFiBerry addon, it wasn't doing any of this at all for days of use until all of a sudden it started doing it.
      The thing that makes this weird though is this is a digital only gamepad. An iBuffalo SNES (or really SFC) style gamepad with an excellent d-pad. I've never had any issues with it in anything else ever before -- including a previous RetroPie setup. In fact, I actually liked it so much I got a second one so I could have one dedicated to the PC and one dedicated to the RetroPie system, so the first thing I did was swap them out to see if it would make any difference and as far as I can tell it's acting exactly the same. They are both exactly the same model, so use the same configuration though.
      Now here's the odd thing. Obviously the first thing I thought of was a deadzone issue. If it were simulating an analog gamepad like PC gamepads used to do before modern USB gamepads and maybe there was a bit of wobble in its output then maybe the system could be picking that up and having an insufficient deadzone. I don't know how to test or edit this in RetroPie. However, I really don't think that's it. When I plug the gamepad into my desktop and look in the system settings, it seems to stay perfectly 100% dead center at all times when I'm not using it (and only doing 100% in a direction if I actually press down on the d-pad.) I do not see it wobble any at all. It never once wanders left or right even by a single pixel, much less far enough to get past even the most basic default of deadzones. It seems hard to believe it would be in any way the gamepad (especially given that both produce the same result.) It wasn't doing it the days I was using it before (not even once) so I really don't think it's the third party HiFiBerry (which really shouldn't be able to do such a thing anyway.) The only thing I can really think of is I did run updates. Both the apt-get upgrade command and the updates from RetroPie's own setup scripts. I can't say for sure if it started right after those or not though... I did also install some optional modules such as the Drastic emulator, but I really can't see how any of them could have caused this. The only thing I can say for sure is that when I unplug the gamepad it stops doing this (I tested this mostly in Kodi watching a movie. I left a keyboard plugged in and unplugged the gamepad. Then it stopped randomly jumping around.) I did plug in a gamepad that acts as an Xbox 360 controller once if this has any meaning (a third party PS2 gamepad in a 360 USB adapter that makes it work even with the Xinput I so hate -- to the system it is entirely indistinguishable from a standard 360 gamepad and uses no special drivers or anything, so it works with the latest retro games that for some reason expect you to use the exceptionally non-retro 360 gamepad but with the benefits of having a real d-pad.) It seems Xbox controllers may use some driver or something, but I did not manually load anything for it or whatever, so if it's doing anything like this it did it on its own.
      If anyone might have any ideas how I could fix this without having to go to extremes like actually reinstalling or something I'd be appreciative. I really specifically want to keep using this particular SFC-style gamepad as it's incredibly comfortable for me and just plain nice to use with retro gaming in general, so I'd really like to get it working right. EDIT: Now here is something interesting... I found the extra settings in Drastic to configure the gamepad to control the menu and... It isn't doing this. I left the cursor on something where left or right movements would register and they never did. I believe Drastic has its own non libretro methods for just about everything doesn't it?
      Pi Model or other hardware: RPi 3
      Power Supply used: EDIT - A reliably tested and more than sufficient power supply. I will not discuss it further. -
      RetroPie Version Used: Well, even though they say don't say latest I sort of have to. The reason being I can't tell you exactly what version I downloaded -- I'm pretty sure it's the same as the current one, but not 100% sure. What I can say is that the setup script reports version 4.2.9 and says last commit two weeks ago (022a7af.) This is obviously after updates. It is possible that it was the previous 4.1 release that I installed on this one, but I'm afraid I just really can't remember.
      Built From: Pre-made SD image from RetroPie site.
      USB Devices connected: iBuffalo SFC-style gamepad and wireless keyboard/mouse remote combo. Nothing else.
      Controller used: both iBuffalo controllers presented the problems
        dankcushions Global Moderator
        if you search for ibuffalo ghost inputs you will see this is a very common problem. i don't get it when i use my controllers via a powered usb hub, but that solution doesn't seem to work for many others.
        • N
          nazo
          Two things: first, as I said, it's not doing it in Drastic which is pretty big. Second, on my PC it doesn't do it in anything either -- and, again, just to be clear, it doesn't just not do sudden "ghost" movements, but there is no wobble at all, not even by as much as a single pixel. Given that it didn't do it before and it's not doing it in Drastic, I think this may actually be related to something that was updated. I really don't want to have to reinstall everything though...
          • simonsterS
            simonster
            Hi @nazo
            You said your power supply was over 1 Amp, that is very low for a Pi3 setup. You should be looking at a 5.2V 2.5Amp power supply as a minimum if you have USB peripherals attached. I'm amazed the Pi isn't showing a lightning bolt constantly. Power supplies have been known to trigger these sorts of issues in the past. Is there another power supply you could try?
            • N
              nazo
              Uhm. Over doesn't mean under. It's not under 1A. 5MA is over 1A for example (note the capital...) I was just saying that it was well within a minimum necessary range. I simply didn't feel like unplugging it to read the exact specifications since I was doing stuff on the system when I wrote that and I already knew it was well over anything the system could need in any realistic scenario.
              BTW, 2.5A is not necessary under any reasonable use. That's if you're going all out plugging in a lot of high powered devices. It would actually be pretty hard to reach that amount through normal usage. Mine isn't even "normal use." It's just a gamepad and a keyboard. Both utilize the low power USB profiles and likely are closer to 10mA than 100mA (nevermind anything like 500mA.) For the record though, it's a 2.1A power supply that seems to be able to pretty reliably actually provide high currents on the few things that can actually use it. If anything it's being underutilized right now as would a 2.5A adapter (I'll check the voltage later.)
              CapemanC 1 Reply Last reply Reply Quote 0
                drastic: may have its own way of coping with/ignoring single frame inputs. games often do. emulationstation, kodi and retroarch (rgui) do not - 1 single frame of input is all that is needed.
                windows will likely exhibit the same behaviour if you recreate the scenario - e.g. use emulationstation in windows and see if there's movement after an idle period. i believe someone did this test but who knows what thread that was in.
                everything you have said so far matches exactly with the 100s of instances of ibuffalo's doing ghost inputs.
                • CapemanC
                  Capeman @nazo
                  Phone and tablet chargers are not very good power supplies for micro computers. Charging a phone doesn't necessarily require precise regulated power, many of them are not manufactured with those standards in mind, especially cheap chinese chargers and mid to low range android chargers.
                  Connect a phone charger to a multimeter and you may notice spikes and drops in voltage, especially when a current load is being drawn.
                  The pi 3 especially needs a stable and constant supply of power to run properly, especially under processor load. I would recommend switching to the official raspberry pi foundation's regulated power supply and then troubleshooting from there.
                  • N
                    nazo
                    Then why didn't it have the problem before? And no, Windows doesn't have this problem. Besides the fact that it never once moved even a single pixel from the center while I watched it, I actually came up with a really simple mechanism of testing: I set JoyToKey to send letters for each direction (LRUD) and set both deadzones completely down to zero with a textbox highlighted. Nothing. If it picked up even the tiniest movement it would show something.
                    I'm not saying ghosting is impossible, but signs point to it being something else. Possibly software even. I would like to diagnose this instead of simply writing it off and refusing to try to fix it. (Also, when I search this it sounds like people are getting different results from what I'm seeing including large amounts of ghosting over very short periods of time instead of one random input over large intervals.)
                    EDIT: I will not respond to "any power supply that isn't the official overpriced one is automatically the cause of any problem you might ever have" style posts. It is a good power supply.
                    CapemanC 1 Reply Last reply Reply Quote -1
                    • simonsterS
                      simonster
                      Because the power usage of a Raspberry Pi is very much linked to activity, it is quite plausible to have different power draw in different installations. Even simple things such as the SD card read/write increase the power load massively. Equally, each emulator actually has its own effect on power draw of the Pi when running, increased higher by using shaders in Retroarch, especially those that apply geometry such as barrel distortion.
                      I still don't understand why people don't buy the official power adapter, and use a mobile phone adapter expecting it to work. That's like buying a new gaming computer without a PSU because you've got an old 250W PSU in your garage and then wondering why your NVidia graphics card isn't working properly.
                      The official power adapter is priced at around £8 from stockists in the UK. If don't think this is overpriced, especially compared to the plethora of tablet PSUs which unless you buy a Chinese knock-off one (really, don't do that) are going to set you back far more money.
                      Back to the issue at hand, if you open an SSH prompt and run a jstest, whilst using the Pi can you see the ghost inputs in the console?
                      • CapemanC
                        Capeman @nazo
                        @nazo said in Spontaneous left/right movements in everything:
                        You'll catch more flies with honey than vinegar, my friend. Just remember that when you show a negative attitude toward strangers who waste their free time trying to help you.
                          mediamogul Global Moderator @Capeman
                          @capeman
                          That's good advice, but I doubt he'll respond to any "vinegar that isn't overpriced honey is automatically the cause of any problem you might ever have" style posts.
                          • N
                            nazo
                            Just to nip this entire derailing in the bud, I tested the power supply's output. I didn't have the patience to wire up a current meter test, but voltage is easy enough. During startup I saw it around 4.99V most of the time, dropping to 4.98V for a split second during heaviest load. Then in the menu it stayed rock-solid on 5.00V most of the time until it had been idling for quite a while at which point it jumped up to a whopping 5.01V fairly stable (still dropping to 5.00V roughly half of the time for a while before it eventually settled on 5.01V, so maybe really closer to 5.005, but my multimeter only goes to the second decimal point.) When the screen dimmed after a long while of idling it jumped up to 5.02V. That's a range of +/- 0.4%. I consider this to be within the 10% most people consider an acceptable tolerance (though my rule is 5%.) The voltage did not budge at all when it finally picked up a "ghost" input.
                            The power supply is neither underutilized nor insufficient. Which I pretty well already knew. This one has been quite reliable for a long time in a lot of applications. BTW, one thing I think you missed is that it's doing this in the menus. That means while idling. So even if the power supply were unable to keep up during heavy use it wouldn't have the same problem idling in a menu.
                            Actually, I've had a chance to test it on another RPi3 using a filesystem image. No "ghosting" on the other. I will be comparing the hardware differences between them next.
                            As for the vinegar, I stated already it wasn't that and I wanted to diagnose the other possibilities. At the very minimum people could have humored me and looked into the other possibilities somewhat instead of repeatedly insisting it was 100% guaranteed to be that. BTW, flies like balsamic vinegar much more than honey.
                            • DarksaviorD
                              Darksavior
                              Beat me to it. I was going to suggest testing different retropie builds. That would prove an update introduced the ghosting.
                              • CapemanC
                                Capeman @nazo
                                @nazo Actually by testing on another Pi3, you may have inadvertently stumbled onto something. There are 2 different manufacturing facilities that produce raspberry pi boards. One is in the UK and the other is out of China. There have been many discussions about the differences in the quality and it's sometimes almost obvious to tell the difference when you see a board from each facility side by side, I have definitely run across both. Might be worth checking out your boards and seeing if they differ in components (easy to spot with the large parts like USB and hdmi connectors). If the ghosting is related to the board that would be good to know in the future. Kind of an outlandish thought, but this ghosting issue has been been around for a long time and there is literally no definitive solution.
                                **Edited for accuracy, i got a beer or 2 in me.
                                • N
                                  nazo @Darksavior
                                  Yeah, something like that may be a possibility. I will be swapping things around and see what happens momentarily. The second one is in a hard to open case though.
                                  @darksavior said in Spontaneous left/right movements in everything:
                                  Here's the funny thing. Same build. It was a filesystem image. I'm going to have to test the two hardware components -- the RPi 3 itself, and the DAC+ addon. The problem is, either one, if it's a 100% hardware issue, is going to be a huge problem for me. The other RPi3 isn't mine and I'm pretty broke atm. The DAC+ I consider non-optional (ask an audiophile about the difference between this and even cheap USB dongles. I have a Fiio E18K that is comparable -- surely better even -- but it's thoroughly dedicated to another task and obviously I can't buy another right now) so if it's it I need to figure out why it's doing it and somehow fix that if it is at all possible without digging into source code or something.
                                  My suspicion is the DAC+. I believe it uses some GPIO functionality. And RetroPie explicitly supports some of the GPIO addons for retro gamepad adapters.
                                  EDIT: The one without the ghosting says "Made in PRC" and has a darker PCB with black plastic on the ribbon connectors. The one I've been using says "Made in UK" and has a lighter PCD with white plastic on the ribbon connectors. I had considered the darker one to be inferior because the TRRS connector has some bit of oxidation or some sort of stain (but I'm not using that analog connection anyway.) I'll test the actual hardware and see what happens.
                                  • CapemanC
                                    Capeman
                                    PRC = Peoples Republic of China. Which strikes me as odd, because i always thought the pi's with the black ribbon cable connectors looked to be made to higher quality standards than the white connector versions. I would have expected the UK to be the better product, but the versions with the white connectors sometimes have crooked connectors that just look cheaper to me.
                                    I just checked, the one i use, which was ordered from Element14, appears to be the PRC one also. From what I've read is the ones from E14 were better built.
                                    Strikes me as odd that the china version would be superior, but, i guess every major tech company including apple and samsung manufacture in china, so i guess the quality can be pretty good if the price is right.
                                    • N
                                      nazo
                                      I'm not seeing many physical differences between them to compare. I actually said I thought that one initially looked inferior because it actually had oxidation on the TRRS connector which striked me as meaning not using a very good alloy (typically they're at least nickel plated these days.) However, I don't know what exactly it is because it doesn't really look exactly like normal rust. It's almost more of an inconsistent brown stain. In fact, it sort of looks like the coffee stains on my coffee press. The metal on the TRRS connector on the UK board is clean and shiny.
                                      Anyway, after I'm done with this test I'll post images. Interestingly enough with the DAC+ plugged into the PRC board I'm not getting ghosting, but, I forgot to switch memory cards, so it's not actually initialized or being used at the moment and the system is using the built-in sound. Honestly, there are several variables and it takes a long time to test since all I can do is just let it sit there a while and see what happens, so this is a bit frustrating. What I can say though is that before when I ran jstest --event I saw a lot more coming up before I switched things around, so right now it seems to be consistent with something in this current setup being "right" and something on the previous setup being "wrong."
                                      N 1 Reply Last reply Reply Quote 1
                                      • N
                                        nazo @nazo
                                        Well... You may be right. I'll be... So here's the thing. I remember now that I actually did switch the two boards a while back. I was having troubles with the power connector on the PRC board being looser (though both seem to be pretty bad and prone to momentary power loss from just a very minor bump of the cord, the UK one was a bit better in that respect and thus I went with it.) I didn't think it made any difference since they keep their's velcroed to the back of the TV and I have to keep mine loose and closer to my speaker amplifier. I performed another test, swapping the memory card and leaving the DAC+ in, running everything from the PRC board and zero ghosting -- unlike what I had with the exact same configuration on the UK board. It just never even occurred to me that there could be actual differences between the boards.
                                        So I guess it must have something to do with the USB handling on the UK board. In fact, this might explain how a powered USB hub could make a difference for anyone if maybe it's dropping power too low or something (perhaps it doesn't like devices that simply don't use much. As I said, this gamepad likely uses exceptionally little power. Less than the wireless keyboard/mouse remote thing surely. One of these days I need to rig up an in-line USB current meter. Some day.) EDIT: As far as quality control questions go, I have to say, the UK board looks like they left bare copper exposed to me. Note how dark many things like the run connectors are. They're obviously not gold-plated as with the PRC board, but if it is copper it has oxidized a fair bit (which perhaps could mean it's affecting the actual lines further down if it has spread.) If it's something else I've never really seen a metal of quite that particular color before personally.
                                        I'll do some more testing and give it more time, but so far I should have seen quite a few events show up in jstest by now.
                                        BTW, I got curious and dipped a q-tip in alcohol. Most of the brown stuff came right off with no real scrubbing. Clearly not oxidation. I just never bothered with it before since I consider the analog output on the RPi to be too awful to use in anything less than an emergency.
                                        EDIT: Now the UK board isn't showing the ghosting either. I guess there is a variable here I may be missing. I may have to test both over a MUCH longer period of time...
                                        PS. Before anyone starts, no I'm not overclocking. The heatsinks are just there because I like all of my hardware to last as long as possible. If I still have a use for this RPi3 in ten years, I want it 100% working. Neither has ever been overclocked and if Raspberry Pi themselves checked them the flag will not have been changed (or does it still do a flag? Eh, if it did it would still say zero or whatever.)
                                        • N
                                          nazo
                                          Well, I'm really having a lot of troubles pinning this down. For a really long time the PRC one produced zero ghost inputs. Then both stopped producing ghost inputs. Now both do both with and without the DAC+ addon. I finally found another gamepad to test with (one I hate, unfortunately) and am running jstest with it. So far zero ghost inputs with it. Meanwhile, now that I know about this jstest, I've rebooted into Linux on my PC and am running jstest on it after installing the requisite joystick package. So far zero ghosting on the PC. I went ahead and plugged in the other iBuffalo and have jstest in another "window" (Byobu) running and it too shows zero ghost inputs. No events at all showing up at all yet except both showed a center a few moments after I plugged them in (which is weird because "no movement" isn't supposed to be an event, yet the value was exactly zero -- aka center.) If I'm assuming it really IS the iBuffalo controller despite all the inconsistencies like the fact it never did it before then it should be producing the exact same result on my PC. Or even just similar results. But no, it's showing zero problems on the PC.
                                          At this point I'm pretty well at a loss. Working with the assumption that it is the gamepad until I can figure out some consistency here, what gamepad similar to this IS good without a bad d-pad? None of that 8-way crap especially. (And I'm definitely looking for something similar to this. For me the SNES gamepad always used to be one of the most comfortable and this one seems to be close enough because it feels just great. Not looking for a PS1/PS2 style controller and absolutely will not use a Xbox 1/360/"One" controller, period.) I'm not overflowing with cash, but at the very minimum I need to tell them what to get and unless I can verify this, I guess I shouldn't tell them to get the iBuffalo.
                                            edmaul69 @nazo
                                            @nazo so i didnt read all of this book but from things i did read. Cellphone chargers do not maintain a constant voltage. The way rapid charge works is it increases and decreases voltage to prevent exploding batteries. The raspberry pi 3's system requirements is listed as 5.1v 2.5a so a cellphone charger will never maintain that. I have only used the white connector versions. I have not had issues as long as i am not trying to power a hard drive from the same power supply. As far as the loose usb connector, the cable can make all the difference. Some are looser than others. Try other cables. A lot of the power supplies made specifically for the pi have a tighter fit.
