    Rpi USB audio woes and other zombies.
    rpi zerousb audio
    55 Posts 5 Posters 16.0k Views
    • HexH
      Hex
      @Xeon I am asking if you can do a clean format. As in wipe SD card and re write retropie image.
      XeonX 1 Reply Last reply Reply Quote 0
      • XeonX
        Xeon Banned @Hex
        @hex said in Rpi USB audio woes and other zombies.:
        Ok each time.
        I did do a proper format.
        Download source.
        https://retropie.org.uk/download/
        But lets do it again.
        I will also do a fresh download and check the MD5 hash.
        Formatted and partition wiped.
        MD5 Compared
        Image freshly written and verified.
        What is the next step?
        • HexH
          Hex
          Boot your Rpi with usb sound card connected.
          From ES select Speaker in volume control and ALSA:HW:1,0 as omx device. Close Settings menu. Open Settings menu again and verify that volume level is saved properly.
          Thats all that is needed. Let me know if it works.
          • XeonX
            Xeon Banned @Hex
            @hex
            The only options in sound settings shown are:
            System Volume
            Enable Sounds
            Back
            Nothing else.
            What next?
            Btw this is really hard to see on crt or Video display had to wait for the display to dim to take this pic.
            • HexH
              Hex
              Thats not possible. What are you running this on ?
              Edit : You are possibly running an older version of ES. Can you update from binary and check again. You should be running 2.5 and up to have this option.
              • XeonX
                Xeon Banned @Hex
                @hex This is the un updated image as seen on the downloads page.
                https://github.com/RetroPie/RetroPie-Setup/releases/download/4.2/retropie-4.2-rpi1_zero.img.gz
                I did no updates.
                So should i only update ES?
                • HexH
                  Hex
                  Yes jut update ES from binary. It should update to 2.6 which has the options.
                  • XeonX
                    Xeon Banned @Hex
                    @hex
                    No wifi will not connect.
                    Even used wifikeyfile.txt
                    Retropie....
                    in a nutshell.
                    So now i am fresh flashing again.
                    • XeonX
                      Xeon Banned
                      From the constant reflashing... the card is now screwed.
                      I think i'm done.
                      Will rather do a project that does not involve a Rpi board
                      • HexH
                        Hex
                        I dont know how I can help you anymore. I followed the exact steps and got my piZ working with usb audio
                        Edit : Do you have any other sound card you could try this on.
                        • XeonX
                          Xeon Banned @Hex
                          @hex
                          I know and thank you for all the help.
                          But it seems the Rpi is literally going to stop me at every corner.
                          Not going to buy another memory card only to waste my life, weekend and money.
                          Parts replaced just getting sound to work.
                          Usb DAC
                          Memory card
                          Power supply
                          Rpi zero
                          not the first time using a rpi
                          but the first time having this much problems.
                          • HexH
                            Hex
                            Let me tell you a tale. While making my GameBoy Zero these are the things I had to replace
                            • Pi zero
                            • USB hub
                            • Sound card
                            • Power boost
                            • Gamepad
                            Here is the album http://imgur.com/a/aQD0M
                            It works well now and it was worth it
                            • XeonX
                              Xeon Banned @Hex
                              @hex I totally understand.
                              Great build btw.
                              But i am utterly frustrated at how many weeks spent on this now just for sound.
                              i have not even added the motion tracking for quake yet.
                              i have not gotten to try start porting Xash3d.
                              I am not having fun.
                              • XeonX
                                Xeon Banned
                                @Hex
                                Ok got a new quality sandisk memory card.
                                Loaded Retropie
                                Now updating ES.
                                Will let you know what happens.
                                • HexH
                                  Hex
                                  I am online let me know.
