    Rpi USB audio woes and other zombies.
    rpi zerousb audio
    55 Posts 5 Posters 14.9k Views
    • HexH
      Hex
      @Xeon You shouldnt have to do that. You could have selected "ALSA:HW:1,0" in the OMX player output device option.
      XeonX 1 Reply Last reply Reply Quote 1
      • XeonX
        Xeon Banned @Hex
        @hex said in Rpi USB audio woes and other zombies.:
        How? Kindly explain.
        • N
          Natron
          If you hit the start button and go into Sound Options, there is an option called OMX player at the bottom. You can select this option, but I found that it didn't work for me.
          I actually have a question for you, @Xeon. Are you noticing any performance issues with the USB audio? I've noticed that my games run slowly with it in use, and in the menu when I have the audio plugged in my frame rate drops by half. I'm wondering if it's specifically my adapter, or if this is some kind of driver or setup issue.
          HexH 1 Reply Last reply Reply Quote 0
          • HexH
            Hex @Natron
            @natron said in Rpi USB audio woes and other zombies.:
            Yes this is the correct way to get USB audio
            @Natron I checked it on a fresh Retropi setup and it worked as expected. Which option did you select ? ALSA:HW:0,0 or 1,0??
            The 0/1 is the device id and :0 is subdevice. aplay -l gives you details about which is your usb sound card.
            • N
              Natron @Hex
              @hex That's odd because it didn't work. I tried both options, actually and got no love either way. I'll go back and reconfigure everything back to normal and try this method out again, though. Maybe I missed something.
              Edit: Nope, still nothing. Oddly, the volume slider always sets itself back to 0% as well when I use the sound settings menu.
              Edit 2: The performance is still atrocious, and fixes itself as soon as I disconnect my USB audio device. I think I'll just have to use this on a regular TV instead of a monitor with speakers. Ah well.
              • HexH
                Hex
                @Natron There are two settings you have to consider.
                1) Master Volume control
                If you want to control volume from ES, ES needs the device being used. For USB audio you need to select Speaker from PCM/SPEAKER/MASTER options. For Pi's own Audio out use PCM. For PC use MASTER
                2) OMX Audio out device
                If you want the Omx player to know which device to output audio from, you will have to set this option.
                Local -> Pi's audio out
                HDMI -> Hdmi audio
                Both -> Both of the above [Default]
                ALSA -> Use Manual settings.
                To test out which works for you, try this command after closing ES from the command line
                # Change the parameter after -o to each of the options to check what works for you.
                # options : local / hdmi / both / alsa:hw:0,0 / alsa:hw:1,0
                omxplayer MY_VIDEO_FILE.mp4 -o alsa:hw:0,0
                XeonX 1 Reply Last reply Reply Quote 0
                • XeonX
                  Xeon Banned @Hex
                  @hex This option not even being possible unless you run the update script.
                  • HexH
                    Hex
                    @Xeon Are you not running the updated ES?? The feature was added a few weeks ago. If you havent updated ES then you will have to.
                    • XeonX
                      Xeon Banned @Hex
                      @hex understood
                      • XeonX
                        Xeon Banned
                        Thanks for helping out a old noob.
                        • XeonX
                          Xeon Banned
                          Yeah i don't know why but the sound still won't work.
                          Not even being detected now.
                          odd.
                          • XeonX
                            Xeon Banned @Xeon
                            I think this usb hub may have a dead port.
                            • XeonX
                              Xeon Banned
                              Nope.
                              tested usb chip in pc.
                              hub port works.
                              just not detected.
                              • XeonX
                                Xeon Banned
                                Ahh it's the sound chip.. it died.. detects on my pc for a few seconds then stops working.
                                • XeonX
                                  Xeon Banned
                                  @Hex
                                  Ok so i replaced the sound card.
                                  Then chose alsa:hw:1,0 as the chip is listed there
                                  Then chose Master.
                                  Still no sound.
                                  Then increased the volume.
                                  Still no sound.
                                  Rebooted.
                                  Volume reset to 0 by itself.
                                  Increased the volume again.
                                  Still no sound.
                                  if i set the volume and exit the menu and return it sets it back to 0
                                  • XeonX
                                    Xeon Banned @Xeon
                                    @Hex
                                    Sound volume drops to 0 the moment Speaker or Master is selected.
                                    PCM does not drop it to 0
                                    • XeonX
                                      Xeon Banned
                                      @Hex When launching any thing i can see the cli where it's launching, i see:
                                      lvl0| VolumeControl|::init() - Failed to find Mixer Elements!
                                      • XeonX
                                        Xeon Banned
                                        After googling online i see no one has provided this much info.
                                        But no one has solved this ever.
                                        Starting to lose hope on this one.
                                        • HexH
                                          Hex
                                          Can you do a clean format, choose Speaker and ALSA:HW:1,0
                                          That should get it working.
                                          I would like to point out to you that if I have not replied you can edit your previous comment to include additional information. No need to create multiple posts. I am sometimes working on code and dont visit the site.
                                          • XeonX
                                            Xeon Banned @Hex
                                            @hex
                                            Will i need to update?
                                            Sorry keep forgetting about the edit function.
                                            If i need to update. "because you need to update to see the sound options"
                                            Then i have done this twice.
                                            Both times had the same result.
