    Is a text carousel possible?
    carousel
    18 Posts 7 Posters 2.8k Views
      Is there a way to make the carousel use text to display systems instead of pictures?
      TMNTturtlguyT OmnijaO meleuM 3 Replies Last reply Reply Quote 0
      • lostlessL
        lostless
        Yes. you can make icons that are text only. Or you let emulation station make the text, but it'll only show the system name. So tubrografx16 is tg16, etc.
        • TMNTturtlguyT
          TMNTturtlguy @lilbud
          @lilbud I was actually just workinon that. You can use the default theme that @jdrassa created, but then you can't have any system folders, there is also no way to control the size of the text box, so long names get cut off.
            jdrassa @TMNTturtlguy
            @tmntturtlguy @lilbud you don't have to use the default theme to show text. If you don't specify a logo in your theme it will default to using text. This has always been the case and is what you would see when a theme did not support a system. What I added along with the default theme was additional theme options for the logoText element.
            You can control the size of the text element, but you can't currently set the font size. Also, due to some weirdness the text element doesn't increase in size properly when selected. I hope to fix both of these issues soon.
            Get latest build of EmulationStation for Windows here
              lilbud @jdrassa
              @jdrassa Could there be a way to use the text properties on the carousel text? Like the text properties that affect the game list.
              • OmnijaO
                Omnija @lilbud
                @lilbud Last that i tried it wasn't possible. If you take a look at my simpler-turtlepi theme you can see that i used text on image.
                Systems: Raspberry Pi 2
                Overclocked: 1050 | 525 | 350 | 425 | 256
                My Themes: Metro Theme | Simpler Turtlepi | Future Mini
                  lilbud @Omnija
                  @omnija oh, okay. So something like this isn't possible for the carousel?
                  OmnijaO J 2 Replies Last reply Reply Quote 0
                  • OmnijaO
                    Omnija @lilbud
                    @lilbud You can if you make images of text then change scroll of it's direction.
                      lilbud @Omnija
                      @omnija No, I mean bolding and changing the color of the selected system. Like that can be done with the gamelist
                      OmnijaO 1 Reply Last reply Reply Quote 0
                      • OmnijaO
                        Omnija @lilbud
                        @lilbud you could try the colour change but id have to say no on the bolding.
                          lilbud @Omnija
                          @omnija How about a way to use different logos for the selected system as compared to the unselected?
                            jdrassa @lilbud
                            @lilbud you may be able do to something similar to your example. You can't change the color per say, but the unselected text will be slightly transparent which will allow the background color to bleed through.
                              lilbud @jdrassa
                              @jdrassa I'm not sure if this was you or not, but someone on this forum had the idea to allow the changing of the carousels origin. So the selected logo could be in the center, or to the left of the screen.
                              Do you know who had the idea?
                                meleu @lilbud
                                @lilbud said in Is a text carousel possible?:
                                (didn't read all the answers above, sorry if I'm being repetitive)
                                I don't know the details but I think yes, cause the "favorites" and "last played" systems on my Carbon are displayed as "FAVORITES" and "RECENT". I'm pretty sure that they are text, cause when "FAVORITES" is the choosen one looks like there's no room for all the text and it says "FAVORI...".
                                  lilbud @meleu
                                  @meleu I think those are images of text, which is sadly not what I'm after. I'm looking to make something along the lines of this. Where the carousel is all text, no images, and it is a different font for the selected one as compared to the non-selected systems
                                  meleuM herb_fargusH 2 Replies Last reply Reply Quote 0
                                    meleu @lilbud
                                    @lilbud Oh, I got it.
                                    I was searching on Carbon repo commit history and the found this PR from @jdrassa . Looks like he is already in this thread here and answered your question...
                                    • herb_fargusH
                                      herb_fargus administrators @lilbud
                                      @lilbud I imagine something like that may be better suited for Pegasus once it's a little more developed
                                        jdrassa @lilbud
                                        It wasn't my idea, but I am working on it.
                                        @meleu is correct. The "favorites" and "last played" all rendered as text in carbon. They are not images. You can now set the font and color that the text is rendered, but you can not specify a different font for the selected one.
