CoolCV emulator no sound issue
I installed the CoolCV emulator on a brand new build of retropie.
EmulationStation version: V 2.6.0 RP
Retropie Version: 4.2.18
Linux: 4.9.35-v7
Pi: 3When I launch any roms in CoolCV, the rom loads fine for graphics but I'm not getting any sound from any of the roms. I've tested the roms on a mac using OpenEMU and they all have sound fine on the computer. But none of the roms have sound on the pi.
Any one else have this issue?
you could always try lr-bluemsx
@herb_fargus Yeah, was just curious if I did something wrong first. Or if it was a weird config setting or something. If I can't figure it out, I'll be trying lr-bluemsx.
@hurricanefan seems you're not the only one: https://www.reddit.com/r/RetroPie/comments/66ser7/coolcv_colecovision_missing_sound/
what version is it showing is installed? I can't remember if we updated the binary. if we haven't it should be available on the atariage forums and can be installed manually but being closed source not sure how much we can do about it
@herb_fargus Dumb question, how would I check what version it is?
@hurricanefan @herb_fargus i updated retropie setup and coolcv and the audio is fine. @HurricaneFan can you press start in emulationstation and go into sound settings and verify the volume is at 100% and not 77% ? Some coleco games arent very loud in the first place.
