RetroPie 4.2 NES 30 Controller by 8bitdo
Why? Is that a question?
Simple, it does not work! not via Bluetooth not via usb it constantly crashes the system locks up and i that state controller and usb Keyboard are not respnosive!
It is not connected it is not mapped nothing i am in the phase of trying to get this junk controller to work.
All my efforts ended in error messages system crashes sytem lockup and i had to disconnect the Power.
I tried with a usb keyboard too that leads to more system lockups sudo halt sudo shutdown nothig works. Its a mess -
@lxevans
People are trying to help you but you aren't providing all the information that would help solve the problem, @BuZz asked for some information that could be useful.
Many of us have 8bitdo controllers and aren't having any of these problems so you're either doing something wrong or there is some other problem with your system.I'm not sure if it's been asked yet but what version of Retropie are you using and where did you get it from?
I assume both, but as long i dont have any clue how to do it "right" i cannot solve the issue.
maybe from the constant on / off with the power cable due crashes and lockups the sd card is long gone the data corrupted. I cannot test if this is the case.
I looked up some retro controller videos and some suggested a Nintendo pro controller maybe i can get hold on one of these an return the nes 30
Firmware of the Controller? i have no idea so i cannot answer questions i have no answers for, thank you for your understanding.
Its 2 oclock in the morning here so...
@lxevans in another thread you said:
the stuff is sold as "retro gaming kit" pi 3 power supply nes case and a 8bitdo 30.
Did you bought a Raspberry Pi with RetroPie pre installed or have you installed RetroPie by yourself?
by the way i'm using RetroPie 4.2 as stated i the topic header, retropie-4.2-rpi2_rpi3.img.gz
A SD Card was not included so i use a Sandisk Extreme Pro Micro SD Card an the Image provided my retropie.org.uk itself.
and yes i bought it, cost me 99.-
a USB keyboard RJ45 Lan cable a HDMI cableso, whats next?
@lxevans Try updating the firwmare of the controller if you have a PC/Mac - see the http://support.8bitdo.com/ page. Using the latest firmware (4.0x), there is no need to use the '8Bitdo hack' option when using blueooth to connect it.
Update the Retropie to the latest version, the image is at version 4.2.0, there are a few improvements since then - see https://retropie.org.uk/docs/Updating-RetroPie/ for the update instructions.
Using the keyboard, unregister all your bluetooth controllers from the bluetooth menu. You alread know how to get to that part (how to get to the module it's described in https://retropie.org.uk/docs/8Bitdo-Controller ).
(Using again just the keyboard) Try again to:
- Register your bluetooth device (pair it) in the Bluetooth module
- Re-configure the input in EmulationStation
@lxevans go to the 8bitdo website. Go to the support section and download the latest firmware (4.01, I believe) for your controller and follow their instructions for installing: then follow the retropie documentation to connect to your Pi and set up controller config.
You said you don't know what firmware it's using, so that could be the issue. If it's old firmware you need the hack turned on for your controller to work correctly.
Also, like I said, don't assume whatever MAC address is detected is your controller. Search again until it's listed as 8bitdo nes30 to be sure. My Pi detects about 5 things in my house that aren't my controllers. -
alright, 8bitdo 4.01 Firmware is on it upgraded via PC USB.
i followed the documentation. no improvement.
i doubt that the firmware of the nes30 cause the crashes on the raspberry pi 3 with the retropie 4.2 on it.
i'm using the newest version i don't see any other versions
sigh -
so whats next
Have you considered just starting from scratch with a clean retropie installation? Preferably use a new SD card as that would rule out any problems with the installation and the SD card. Sometimes it's just easier to start afresh.
beg your pardon? the sd card cost about 100.- and is used for 4K GoPro Videos i cannot just buy stuff like this whenever i pleased to. and since it's still Version 4.2 what difference would that made?
@LXEvans the curious thing is that on your OP you at least saw the EmulationStation configure input screen and were able to set some buttons... To reach this point you have to connect/pair the NES30 before.
I think this is what is confusing all the guys that are trying to help you (including myself).
Can you say how you reached that point (EmulationStation configure input) in the first place? Looks like you were able to connect/pair the NES30 before and now you're facing problems...
@lxevans
I don't see what difference the price of your SD card makes - it could still have a fault or be corrupted so I was offering you a suggestion to fix all the problems you're having. And why do you need such an expensive card? You can buy very good SD cards for under £10 that work perfectly with retropie. -
it seems that was too cryptic: i can't afford to buy new micro sd cards every week. 10 bucks? the stuff is too slow.
i contacted brack about the Pi 3 / nes 30 and Sandisk about the SD Card, both did not answer.
i also don't see the point why i have to chance my entire hardware here. except the Raspberry Pi Power Supply there is nothig left.
@lxevans Reflash retropie on your micro sd. Start again. Some files may have corrupted when you pulled the power, not necessarily damaging the micro sd itself.
Follow the setup guides exactly to the word, and you will have success. -
@lxevans
Ridiculous, a £10 SD card is more than fast enough for a raspberry pi (sandisk ultra can bought in this price range which are class 10 80mb/s), your read speed will be limited by the speed of the raspberry pi anyway.Numerous people have offered you suggestions, none of which worked according to you, and no one else is having these problems. I don't see how much more help people here can give you.
"no one else has problems" are you sure?
the "suggestions" as you call it i used a few of them, they did not work.
for the "replace the whole hardware" that is gonna take a while, the sd card can go on its way in the next days the "gaming" kit i have to wait for a response from brack. the importeur from Sandsik was not very pleased as i asked for a replacement.
the only thing a can do is to try and try it again, the system locks up, crashes, the nes30 does nothing.so what are your suggestions? ruck
@lxevans said in RetroPie 4.2 NES 30 Controller by 8bitdo:
No one said to replace your whole hardware, I suggested reinstalling retropie from scratch (as did @gaavoid ) and preferably try a new SD in case that was the problem (things such as SD corruption could be the cause so its wise to rule it out .)
No one else is having these problems, if they were there would be dozens of threads reporting it as a problem - as I said many of us have these controllers and don't have any these issues (the nes30 is a very popular controller).Your only contribution here so far is to ask for help, which is fine, but despite several people giving up their time to offer assistance you've ignored suggestions and some of your responses have seemed quite rude. I appreciate you are probably frustrated with the problems you're having but that isn't our fault - a little respect goes a long way. There is only so much we can do to help especially if you refuse to accept the advise offered.
fair enough, so what exactly do you want to know?
if i recollect this right the "suggestions" are:
reconnect the nes30 - tried that several times
remove and add it again with bluetooth - tried that several times
update the firmware - done on 8bitdo Homepage
update retropie 4.2 - done
switch SD card - in progress
wipe and reinstall with etcher - tried that several times toowhat are my "contributions":
describing what the problem is, version numbers of all programs involved, screenshots of the error messages, what happend after i tried the solutions provided.
as i stated before the issue is not only the nes30 controller, after i try to install / connect it retropie goes nuts an locks up / crashes / freezes no input not even with the USB Keyboard.
what lights up on the controller?
blue blinks occasionally, if i press L R Start green and blue blinks for a brief moment.so thanks goes to all who wrote me and invested time an efforts into it
thanks a lot - merci beaucup - vielen dank
rude enough?
