    Ultimate Dual Fan for Pi3
    pi coolingcooling fancooling
    52 Posts 12 Posters 16.0k Views
    • spruce_m00seS
      spruce_m00se
      Laugh away, but she plays quake 3 arena all day without going over 45C, and thats in a 28C ambient temp.
      It sure not a space saving design though.
      caver01C tyman82801T DD-IndeedD 3 Replies Last reply Reply Quote 0
      • caver01C
        caver01 @spruce_m00se
        @spruce_m00se I'm not laughing. That's great. Did you power the fan externally? USB? or did you pull it from a 5v rail pin on the Pi? I would consider this myself.
        • spruce_m00seS
          spruce_m00se
          Its a 12v fan, I have a 12v supply in the arcade cabinet that runs the RGB mood lighting and will soon run the car radio im going to use to augment the "jukebox" functionality as thats what I use most, I have the 12v supply on a relay board controlled by an arduino that also controls the power on and off of the tv and the volume, it will soon also power down the pi via gpio. the plan is to add temp probe to control the fan and I have done initial tests with a micophone to auto adjust the volume so that when one rom or song is louder it will auto turn it down.
          but yeh the fan is 12v in a 3d printed duct
          • tyman82801T
            tyman82801 @spruce_m00se
            @spruce_m00se, i would do the same thing if i had an extra fan
            • spruce_m00seS
              spruce_m00se
              just buy one then, they are like 5 usd........
              • DD-IndeedD
                DD-Indeed @spruce_m00se
                @spruce_m00se
                That's not laughable, it's a must-to-do in very demanding processing and heavy overclocks. Besides, those big fans are quieter than smaller ones and it's easier to find replacement fans in that size. In arcade cabinet, the size not a problem either.
                My soul rests, when I hear the PS1 boot music
                • EcksE
                  Ecks @PetroRie
                  @petrorie said in Ultimate Dual Fan for Pi3:
                  @caver01 said in Ultimate Dual Fan for Pi3:
                  @livefastcyyoung Yes, not to mention the fact that if you are running emulators, or ROMs that push the limits of the Pi3, I noticed an immediate difference in just adding a heat sink. Any cooling, whether active or passive will be of benefit if attached correctly.
                  I had only once heating problems and that was during a hot summer day, I;ve took the top cover off. The thing I don't like is that these heatsinks are way too small because of the cases. You can use a 40mm 40mm heatsink with a fan but you have to "mutilate" your top cover.
                  You do know that most cases out there for the Pi tends to have cutouts for the GPIO and for the LED touch screen and for the camera and yes i know not all cases has it for all 3 of them but still proper ventilation and besides that.
                  Also when people buys a fan for any system they don't buy them for overclocking purposes they mainly get it cause one they like to have less than 60°C and two they read their manual before even setting up the system and found out going over 80°C voids the warranty which if there is a problem with the unit they would not be able to return it for that purpose.
                    dankcushions Global Moderator @Ecks
                    @ecks said in Ultimate Dual Fan for Pi3:
                    your pi will downclock before it goes over 80. so it's impossible to go over 80, basically.
                    EcksE 1 Reply Last reply Reply Quote 0
                      A Former User
                      REGARDLESS, this fan serves more than just people who are overclocking. Definitely worth it in my opinion. A tad noisy, but it could also just be the shelf my Pi is sitting on. Far better than just using the dual heat sink set you see everywhere.
                      • DD-IndeedD
                        DD-Indeed
                        Btw, prices of this dual fan have rapidly gone up over recent weeks on Ebay, from 6-8 € up to 50 €!
                          A Former User
                          Went up $3 on Amazon. Was $12.59, now $15.59. Free shipping. Still not unreasonable.
                          DD-IndeedD 1 Reply Last reply Reply Quote 0
                          • DD-IndeedD
                            DD-Indeed @A Former User
                            @livefastcyyoung
                            Well strange thing is that the prices have gone up with chinese sellers. Bigger retailers still have then in in reasonable prices, allthou, they are varying.
                            • EcksE
                              Ecks @dankcushions
                              @dankcushions Actually there is people on YouTube that does temp tests for the Pi 2 and 3 in which has shown temps going over 80
                                @ecks my mistake, it throttles at 82 degrees C. my point stands - your warranty isn't voided. there's nothing in the manual to say that it does, either.
                                • EcksE
                                  Ecks @dankcushions
                                  @dankcushions Alot of products now a days doesn't really tell you what can or can not void a warranty from a manual it would mainly tell you on the main site or a dev on twitter will tell you instead because one system i own which is the Nvidia Shield TV has no where on the system and manual on it being voided if you open the system but on the main site they tell you there.
                                  • DD-IndeedD
                                    DD-Indeed
                                    Finally the cooler arrived, I can put it in and do some benchmarks. I will use my current cooler first for the tests, then take it off and try again and then with the dual fan cooler.
                                      ok, so where on the raspberry site (or raspberry dev twitter) does it say that over 80 degrees will void your warranty?
                                      • DD-IndeedD
                                        DD-Indeed
                                        Man, this is so cute, I put a lighter next to it to give some scale :D
                                        The double sided tape that came with it was actually thermal tape with sticky sides, so it could actually be good. But nevertheless, I'll do the tests with other things first.
                                        • spruce_m00seS
                                          spruce_m00se
                                          i like the non standard size lighter for scale :)
                                          • DD-IndeedD
                                            @spruce_m00se
                                            The blades themselves are roughly the size of certain coins, so they're really small. I have some pessimistic feelings about this, since it is very small, but we know more later today. :)
